Jon Pop Posted May 27, 2016 Share #1 Posted May 27, 2016 Advertisement (gone after registration) I'm shooting with a 35mm Summaron f3.5 LTM (lovely lens of course) on my iiif and iiig and occasionally find myself in need of an ND filter to limit the amount of light...I often push my film to 800 or 1600 for daytime street shooting at f8-11 for quick shutter speed, zone focusing, etc. And of course for shooting into the evenings. Sometimes I'm stuck with that faster roll in the brightest daytime and the 1/1000 and f16 isn't enough to avoid overexposure. Has anyone seen any a36 ND filters, or alternatively the little 19mm filters that screw into the front (I could also use a 19mm on my Elmar 50 f3.5 and still access the tiny aperture tab as well). eBay hasn't proved successful....lots of colour filters of course. Any tips? Best Jon Quote Link to post Share on other sites More sharing options...
Advertisement Posted May 27, 2016 Posted May 27, 2016 Hi Jon Pop, Take a look here ND filter - A36 or 19mm. I'm sure you'll find what you were looking for!
sandro Posted May 27, 2016 Share #2 Posted May 27, 2016 Hi Jon, an adapter exists to use E39 filters on a lens which takes A36 screw filters: SOOGZ. The other adapter is the SGOOZ to use E39 filters on a lens which takes A36 clamp-on filters. I think this second one may be helpful to you. Lex 1 Quote Link to post Share on other sites More sharing options...
Jon Pop Posted May 27, 2016 Author Share #3 Posted May 27, 2016 Perfect! I'd forgotten about that one...the SGOOZ is exactly what I'll need. It's nice to be able to use my existing e39 ND filter! Thanks so much. Quote Link to post Share on other sites More sharing options...
Guest JMF Posted May 28, 2016 Share #4 Posted May 28, 2016 (edited) E 19 filters ND are harder to source than UV ones which are available : https://camerafilmphoto.com/all-products/heliopan-uv-haze-filter/ The old Walz filters for the Argus C3 are more common. Edited May 28, 2016 by jmanivelle Quote Link to post Share on other sites More sharing options...
Guest Posted May 28, 2016 Share #5 Posted May 28, 2016 ... 35mm Summaron f3.5 LTM ... any a36 ND filters, or alternatively the little 19mm filters that screw into the front (I could also use a 19mm on my Elmar 50 f3.5 and still access the tiny aperture tab as well)... At the experts: For Elmar 3.5-50mm ltm I use four 19-mm filters, two original Leitz and two made by Hoja, which can be all screwed well. But none of these 19-mm filters fits on the Summaron 3,5-35mm ltm. Above the Serial-No. 1284xxx I mean to see a thread, but with a slightly larger diameter than 19mm. Which filter size could that be? Quote Link to post Share on other sites More sharing options...
sumolux Posted May 28, 2016 Share #6 Posted May 28, 2016 Jon, The 19mm filters are regularly available on eBay actually; I acquired a ful set one by one. The trick is to look for them on the separate eBay sites, ending in .uk, .de, etc. Not all eBay listings are put on worldwide, there is a FIRHE for sale now on the .uk site for instance. The 19mm filters have the pluspoint that you can change the F-stop on lenses like the Elmars without having to take a (larger) filter off first. Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted May 28, 2016 Share #7 Posted May 28, 2016 (edited) Advertisement (gone after registration) Mnutzer, Screw-in filters for Summaron A36 ? Never heard of... but it's true that, apparently, the black front ring looks threaded... 21mm... even not the same diameter as the old Hektor 5cm (20mm) for which some author says that a proper screw in filter was made (GG type ? info isn't clear and never saw codes) Edited May 28, 2016 by luigi bertolotti Quote Link to post Share on other sites More sharing options...
Jon Pop Posted May 28, 2016 Author Share #8 Posted May 28, 2016 Thanks everyone - it's definitely only an ND filter I'm looking for. I've seen sets of 19mm and of course the A36 clamp on (my summaron has no threaded 36 ring, unlike my 90mm Elmar f4, so it needs A36 clamp-on filters). I've just never seen an ND filter. Since I shoot with colour and black/white, a dark red (for example) would likely work not bad for limiting light but of course couldn't work for the colour film. I have a good set of E39 filters (use them for my 50mm Summicron M, my 35mm Summaron M and the CV 28mm f3.5 Color Skopar). The problem I'm having now is that some of the eBay sellers have what I think are SGOOZ but in pictures I think they're actually SOOGZ and vice versa. So I'm having to review pics to ensure, in the end, I have a device that lets me add my 39mm filters to a clamp on device for the A36 front of the Summaron (I could also use it also on my Elmar 90 f4, but with an aperture of f32 I'm not likely to have any issues and don't use it much anyways). Jon Pop. Quote Link to post Share on other sites More sharing options...
