忘不了 Posted April 17, 2016 Share #1 Posted April 17, 2016 Advertisement (gone after registration) First, DNG automatic noise reduction set or no switch. Second, SL is the 1.1 firmware in the M file to support the wireless flash, upgrade 1.2 and 2 firmware can not use the PROFOTO Wireless Flash (TTL-C Canon) and Canon ST-E3 wireless flash. 1.2 and 2 firmware Canon 600EX top flash can be used, PROFOTO wireless single point and (TTL-N Nikon) flash can be used. It seems only for the camera. 第一,DNG自动降噪设置还是没有开关。第二,SL是1.1固件在M档支持无线引闪,升级1.2和2.0固件无法使用PROFOTO无线引闪器(TTL-C佳能)和佳能ST-E3无线引闪器。1.2和2.0固件佳能600EX机顶闪光灯可以使用,PROFOTO无线单点和(TTL-N尼康)引闪器可以使用。看来只有换相机了。 Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! NeuMo 1 Quote Link to post Share on other sites More sharing options...
NeuMo Posted April 17, 2016 Share #2 Posted April 17, 2016 Very interesting combi, SL + Profoto wireless flash N-TTL. Please tell me more about this !!! Quote Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted April 17, 2016 Share #3 Posted April 17, 2016 (edited) Mate. you need to get over this. Every one of your 60 posts are about this. It's time to start looking for solutions that don't involve a firmware change on the SL because that ain't going to happen. A simple single pin hotshoe adaptor will likely solve the issues you're having with a non-Leica TTL shoe on a Leica camera. 5 bucks on eBay. Here's one. http://www.ebay.com/itm/SYK-4-Camera-Flash-Hot-Shoe-Sync-Adapter-Slave-Trigger-/280296557201?hash=item4142fa0a91:g:5ZYAAOxyB0VRsd76 you'll need a short cable to the pc flash socket for it. You might be able to find a pass through version. i probably have 5 of these in a drawer already. It's not Leica's job to support non Leica triggers on Leica cameras. it's not a fault. It's probably a deliberate thing to protect the shoe circuitry. The Nikon version probably fires because the pins line up. the Canon one only gets two contacts and the camera doesn't think that's a good idea. You need to remove the contact from the four Canon TTL pins on the trigger from touching the hotshoe. Then *IF* the Profoto TTL trigger is actually capable of working as a totally manual trigger and *IF* you have the trigger set up properly to do this (I remember what a pain it was to get full manual the Pocket Wizard Canon TTL system). you should be fine. I use Godox and Elinchrom triggers nearly every day with no issues. I'd also be concerned you have cooked the shoe, if it were me. Gordon Edited April 17, 2016 by FlashGordonPhotography AlanJW 1 Quote Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted April 17, 2016 Share #4 Posted April 17, 2016 p.s. I totally agree with you about the long exposure noise reduction. It should be able to be switched off. I can think of many instances where this would be useful. I can also think of a dozen other things, just off the top of my head. leica did good with 2.0 but the SL still has a ways to go to be all it can be. Gordon Quote Link to post Share on other sites More sharing options...
Ingo Posted April 17, 2016 Share #5 Posted April 17, 2016 The Profoto Air remote (non TTl-version) works perfect on the SL (I use it). Of course you have only manual mode. TTL-versions are only available for Nikon or Canon. Quote Link to post Share on other sites More sharing options...
忘不了 Posted April 18, 2016 Author Share #6 Posted April 18, 2016 The Profoto Air remote (non TTl-version) works perfect on the SL (I use it). Of course you have only manual mode. TTL-versions are only available for Nikon or Canon. TTL-N can trigger, 1.2 firmware test can, 2 no test. TTL-N可以触发,1.2固件测试可以,2.0没有测试。 With coke or very rubbish, ready to out of the SL. 跟焦还是非常垃圾,准备向出了SL。 Quote Link to post Share on other sites More sharing options...
sillbeers15 Posted April 18, 2016 Share #7 Posted April 18, 2016 Advertisement (gone after registration) Leica is not suitable for you. Bring along your desired wireless flash remote to any camera store in China to match a camera that works for you and hence you can stop your complain. sdw 1 Quote Link to post Share on other sites More sharing options...
