Leica Focomat 1c ...broken part
crow
Tobey, I respectfully disagree
The first version Focotar 50/4.5 when stopped down twice is very ok. For sure up to 30X40cm. I think to learn to print, a 1c with that Focotar is fine. People can then upgrade to either one of the later two Focotars. After all, you and I also did not start using a 1c with Focotar-2 or the Schneider made Focotar, did we?
And, I much prefer someone tries to repair this beautiful enlarger and learn something about it while at it. Every saved quality enlarger is a plus in analogue's battle to survive.
Finally, in the past two years I found about ten short neck bulbs in 150 watt ! The 75 watt is still easier.
Michael
No that why I am trying to get OP started right.  The correct things are not as plentiful now.
He also can not solve the buib problem without making a spacer ring.
And there is the issue of the machine may or may not have the AN glass to go over the condenser.   I would not work without one.  They be as difficult to find as the proper short neck Osram bulb.
This thing is asking for trouble.
  • 2 weeks later...
