Your Ultra Wide Angle (UWA) Pictures (10mm to 21mm)
hiepphotog
How well does the ZM 21 Biogon behave on the M240? Do the in-camera profiles correct it enough, or does one have to use the flat field plugin?
I really wanted to like the little CV 21/4 but I think I just had a bad copy, the corners never ever got even close the concept of "sharp". Wound up getting the 21 Ultron which is indeed impressive, but I find I don't use it much due to its size / weight.
However it doesn't leave me wanting when it comes to end results.
SEM 21 with 240MP shot facing the sun. Impressive detail resolution on the left from the far away landscapes.
  • Like 13
Leica M (Typ 240), CV12mm/f5.6
OOC, only LR default development of DNG to JPG, NOT corrected by CornerFix or FlatField.
By the way, CornerFix does an excellent job here.
La Paz, Bolivia
  • 4 weeks later...
Leica M 240 and the SEM 21/3.8, a truly lovely lens.
Edited by WeiterWinkel
Another one, same combo: M240, SEM 21/3.8
I probably have the least exotic UWA here: the Voigtlander Color Skopar 21mm M. I went for the M mount version over the LTM simply because I liked the way the focus knob felt. Since I'm not much of an UWA shooter, the Skopar is a winner for me since it takes almost no real estate in my bag.
Here's my first shots taken at my parent's place in Asheville, NC, USA with a Leica M9.
Milano, M8 with CV 15mm, from the roof of Il Duomo
Edited by otto.f
Split, Hradice
MM1, CV 15mm
(Don't see why my uploaded images have a lower quality since my Premium Membership, but time will tell)
Edited by otto.f
Mereworth, Kent
M-P240, CV 15/3
Is there a reason for the rather unusual effects in the sky?
I'm suspicious of the large image size, 17.8" X 11.9", but very low, 72ppi, resolution of the Jpeg file.
You are quite right to be suspicious - I had completely forgotten that I had cropped the original by quite a lot. I should never have posted it on this thread - I shall be more careful in future and check the original. My apologies to all, but no deception was intended!
The sky - it was a very dull day, and it had virtually no interest at all, but I managed to tease out of it what you see, and rather liked the effect, artificial though it may be.
I'll look for something uncropped from the same lens......
