soundsgoodsg Posted October 20, 2015 Share #1 Posted October 20, 2015 Advertisement (gone after registration) I love having a half-case on my T but the biggest bug bear is having to remove it to access the SD card / USB ports or to do a battery pull to unfreeze the T. I've discovered that the connector for a black rapid sling, aside from doing what it was designed to do, also acts as a very convenient handle for unscrewing the half-case. It has a rubber pad so when tightened it's very stable, but when you undo it, it also takes the half-case screw out easily. Not as cheap as fishing into your pocket for a coin, but seems to work nicely and looks decent, too! Quote Link to post Share on other sites More sharing options...
Advertisement Posted October 20, 2015 Posted October 20, 2015 Hi soundsgoodsg, Take a look here Easy Half-Case Removal. I'm sure you'll find what you were looking for!
Paul925 Posted October 25, 2015 Share #2 Posted October 25, 2015 Thanks for sharing this tip. It is good to know there are other options. Quote Link to post Share on other sites More sharing options...
