Joewdwd
Best flash for Leica Q
Mounted my SB24 on my new Q but it only fires when the flash is in Manual or Automatic.  Does not work on TTL.  Does anyone know if the SB24 is meant to work on TTL.  If not then has anyone had experience with any other flashes.
Share this post
Have the SF58 which worked inttl when I tried it but it really is overkill on the Q. Don't know what the position is now with leica and flash as Metz has now gone out of business. Probabaly best off withthe SF26
Share this post
I think Leica needs to bring out a new small version to match the camera in size. Something sleek and designed for amateurs rather than big bulky professional ones
Share this post
Only SF26 is shown as flash equipment on Leica Q official homepage. Any review on this flash or other suggestions?
Share this post
I have the SF26 on the Q. Seems to work well where a bit of fill us needed. Obviously, not a strong flash which is great when one prefers available light anyway. Small, light and adds a touch when needed. It is adjustable to fire indirectly as well.
Share this post
I too have the SF 26 and find it works well.  A bit expensive when the Metz version (only difference is firmware) sells for $129 but unfortunately, the Metz version does not work (I tried it).  There was a firmware upgrade available for the Metz to make it work with the Leica D-Lux series and that might have made it work but it was a Windows only update and required a Windows driver install.  I set up a Windows 8 bootcamp partition on my iMac but I could never get the Windows system to recognize the USB device so I couldn't install the upgrade to test it.  I didn't have a true Windows machine to perform the upgrade so I gave up on it and bought the SF-26.  The TTL mode appears to work pretty well but will overexpose on direct if too close to the subject.  Doesn't work quite as well as the Olympus TTL flashes but with minor adjustments works well enough for my uses.  I prefer not to use flash but fill can come in handy and making a dark interior look a little brighter also helps.
Share this post
I am debating ordering the SF 26 for my Q. I took a bunch of people pictures indoors with sunny windows in the scenes and the faces were all seriously underexposed while the highlights were preserved by the Q. So the camera did it's thing exposure wise but this situation obviously calls for fill flash. Hence I'm debating dropping $300+ for the SF 26. I have a couple of questions for those who have this flash:
1 - are all, or any, angles possible for bounce flash mode other than 0 degrees (head on) or 90 (to ceiling)?
2- the specs say "Also, the flash has a constant LED video light with 2 output settings and a maximum output of 30 lux at 3.3'." That sounds interesting - has anyone tried this? Are the levels bright enough to be useful? This would certainly be nice as people cringe and squint and generally loathe being flashed. Also - if I understand this LED light, it might also be a nice feature for lighting closeups in the Q's very nice macro mode.
3- Is the size and weight of the SF 26 relatively low so that it still is a fairly small nice package? If someone has a picture of it on the Q, then would be great. They quote the weight as 4+ ounces so that seems ok (not sure if that is with the AAA batteries, probably not).
Share this post
The best flash will be the one that fits your needs. From the specs the new SF40 is far better in most aspects as the SF 26 is. And it is just 80,- Euros extra compared to the SF26 but I do not regret that I bought the SF 26. I do not use it very often for me it is a kind of an insurance for the rare situations where I might need it and for that purpose it is the best flash for the Q, it is so tiny that it even fits into my small Fogg flute bag and that light that I even do not notice if it is in the bag or not. BTW it always is in there, right under a small trap door divider.
Share this post
This SF40 looks to be more than twice the weight than the sf26 and is probably quite a bit larger. The specs say is is for 16-105mm lens, so isn't this overkill if I plan to use it only for the Q? It looks like the sf 26 is the one to get  for a basic, compact fill flash for the Q. No?
Also, I wish someone would answer my two questions:
Is the sf 26 adjustable in any direction other than up or straight ahead?
Have you found the so called LED video light useful?
Share this post
I'll most likely opt for the little EF-X20 as I prefer a manual flash and it should be a good fit in terms of size.
I just watched a youtube video about this last night. Does anyone know a light and small way to get it off camera?
Share this post
Funny, I have one of those and I forgot about it until now. I'll try it.
To those who have purchased the Flash Q: are you satisfied with it with the Q?
Share this post
Yes, works very well. Gets the flash off the camera and syncs well. I use the SF24D on manual and sit the flash on a polarois pistol grip/tripod as follows.
Edited by Rapierwitman
Share this post
I too am using the SF 24D on the Q set at A (couldn't get it to fire at M or TTL ) but am finding it to
be just great for fill flash maneuvers. Setting aperture, shutter speed and ISO for slow exposure (f4,
1/30th,ISO 400)of the background, and second curtain sync at -1 exp comp(on the 24 D, not on the camera)
for foreground, am getting gorgeous results. Have always considered flash to be bad grammar with Leica
lenses and machines,but this is kind of fun. Good luck!
Share this post
I'm thinking of buying the EF-X20 as well. It's compact and I prefer manual control anyway.
So far I found one video on youtube https://youtu.be/Zjkwhv-xc5k
Anybody else having experience with this combination?
Share this post
Loading...
  • Similar Content
    • By Knives52
      I picked up a Leica SF24D flash recently to use with my M6TTL. I was thinking about testing it with my Canon EOS R dslr and using its screen to get familiar with the flash without wasting film (I don’t mind if it will only work using Manual mode on the flash).
      I think I remember hearing years ago something about TTL flashes not pairing well with some newer “more-electronic” cameras’ hot shoes and possibly frying the camera’s electronics — though my memory’s extremely foggy on that.
      Does anyone have any experience using the SF24D on a dslr of any make/model and/or on any digital Leica body?
      Would covering the flash’s 3 “TTL connector pins” on its hot shoe with electrical tape (while leaving the main center pin uncovered) be necessary or safer?
      Apologies in advance if this is a dumb question.
    • By UltraDan
      Hi there,
      Can anyone offer me some simplified advice for using a flash with my m4p, I have an old sunpak auto 140 flash that is non settable and is activated via the ports on the back, what I wanted to know is :
      how do I gauge my shutter speed and aperture for two situations 1) outdoor in good/fair light 2) indoor
      and is it better to use one of the ports over the other (M or X)
      Thanks in advance,
      Dan.
    • By bgreig
      I am using an SF40 flash on my Leica Q. What is the best way to use the flash for fill while shooting in automatic aperture and automatic speed mode? In automatic speed but a specific aperture?
    • By michaeltmonaco
      Hey my name is mike and i've had my m4 since june and absolutely love the camera.  I got it cla'd by yye camera and it works great.  Only issue is I love to shoot with flash and when I try doing so with this camera it is extremely unreliable..  I have never used the leica brand pc sync cord's and was curious if that could be the issue, but have tested the cords I have on all of the other film cameras I own and they work no problem at all.  I have the vivitar 285hv and that comes with a sync cable already attached to the flash then put the other end on the socket of the camera and it works about 10 percent of the time.  My other method was buying a hot shoe adapter and then putting my metz flash atop / and or my small nikon this again only worked rarely and with intense fidgeting of the cable.  If anyone has any advice I would really appreciate it.  Thanks a lot.
      Best,
      Mike
    • By NRKstudio
      To the forum gurus:
      For my SL2, I am seeking a good on-camera flash with radio transmitter capability, plus a controller for it.
      I have the SF40, and it’s not making the cut really.  TTL is decent tho, but I just read “The Flash Book” by Scott Kelby and his system is all about setting the flash/camera (move the flash off camera if possible) to Manual mode (1/4 flash power, iso 100, 1/125 sec, f/5.6)and just adjusting the camera from there.
      So what have y’all been using for a good hot shoe flash and a radio controller??
      The SF58 and c1 remote are out of my budget unfortunately! I’m an amateur photographer who shoots just my toddler and wife, and some friends/family events.
      thanks in advance for the guidance!
    No registered users viewing this page.
Important Information
