UV IR filter as protection on M9?
XVarior
Any filter will affect the image. The amount is so minimal, however, that it is of no practical interest.
The lens is least affected and best protected if you use a real protective filter like the B&W 007 filters as they are extra thin and made of impact-resistant glass.
But use your Leica one by all means.
I use UVIR filters on my M9 and Mtype 240s. I do see some IR contamination at times (I'm a wedding photographer- synthetic fabrics are my every day. They're not recommended for ultrawides but on everything from 28mm you should be fine. I have no issues on any of my lenses, including my 35mm lux.
Gordon
I use the UV/IR filters on all my bodies, because all digital cameras have some sensitivity to IR light, the M8 more than the M9 but still quite a bit, and the M240 more than the M9 but less than the M8...
Oh wow, Jip, your input is about the only positive one regarding this filter M9-IR combo. in case it would enhance the image, in which lighting situation could that be and in which situation you think it could go wrong?
thanks again for your input.
I have had serious IR contamination in stage/theatrical work in particular (the major culprit is synthetic black fabrics that abound in these scenarios), but also with tungsten lit motifs using the M9. Once I added the UV/IR cut filters from my M8 days the problem dissolved. I now leave the filters on my lens set permanently and have noticed some benefit in the representation of some greens in landscape work as a side benefit.
The only downside of filters is intenal reflections that can happen when shooting light sources in frame (night scenes) some times. This is true of ALL filters.
Guest volker_m
UV/IR on ALL digital is good practice.
IR-cut filters cause color shift if the light doesn't pass exactly perpendicular to the filter surface. You can easily see the color shift if you look through an UV/IR filter at an angle. This effect can be very annoying if you add UV/IR filter in front of wide angle lenses.
The M8 did remove that color shift from the RAW data, based on the detected lens code. The newer bodies don't expect and don't remove color shift from UV/IR filters, so this needs to be done manually by the user.
Using a plain UV-cut filter avoids the color shift issue.
While I have no issue using UV/IR filters on many of my lenses, it should be noted that the filter manufacturers do indicate that the UV/IR filters are recommended for use on lenses with a angle of view of 60 degrees or narrower ... ie ~35mm and up. Wider lenses will exhibit varying degrees of colored edges that may or may not be adequately dealt with by software profiles.
Guest volker_m
The eye is not a camera.
The "green corners" side effect of UV/IR is pretty obvious with the camera. The wider the lens, the more obvious it is.
Examples below are with M9 and Summilux21, shot against a white wall. First picture without filter, second picture with Leica UV/IR filter added.
Unlike the M8, the M9 does not automatically remove the color shift because it is not designed for UV/IR filter use.
The wonderful thing about digital is immediate feedback, I like to do my own testing on these matters. I also like uv/ir filters, so a simple test would be to shoot some pictures with and without the filter on the body/lens/subject/lighting situation and then your decision is evidence based. If the uv/ir filter degrades the image consider replacing it, however the situation may cause any filter to degrade also, therefore replacing the uv/ir with a uv or cover glass filter may net you zero.
