jinfinance M mount issues
JohnJWhite
The Testors glossy black and white are now working perfectly on my M 240.
Where these older Jin flanges and what focal length lenses?? My type 4 35 sum, older 50 sum (circa 1979) and 90 tele elmarit-m (thin) don't work at all on the m240 but perfect on the m9
The jin mounts are all new, within the past two weeks. So far I have the 90mm Elmarit-M 1:2.8/90 and the Tele-Elmar-M 1:4/135 working perfectly.
Rong Jin has the correct mount for my 21 and is sending it out right away. I had ordered the incorrect mount, so, not their fault.
GM car paint works fine, universal black and Arctic white.
Very possibly two other issues. The camera needs to see the correct frame line automatically,
Bigger potential issue is the pits are wider on factory coded lenses. The 240 may actually be seeing chrome next to the jinfinance black areas giving incorrect reading.
To further complicate matters, many I bought were .040" thick. The one that came off the camera was .039. Front focus resulted and I had to thin the mount.
If I had a 240 and knowing what I KNOW TODAY, I would buy new lenses, or have leica code and calibrate, or manually set in the camera menu.
Mine work fine on the M8 & 9 , after a lot of screwing around. That is part of what keeps me from buying a 240. Leica seems to be perpetually fixing problems with rangefinders , red edges, lens coding, etc. Their service is not that good and I do not feel I should have to keep sending stuff in to be modified. Their cameras are in a perpetual state of modification since digital.
