jinfinance M mount issues
JohnJWhite
I recently purchased 3 mounts from "jinfinance" in China. I have older lenses, 70s and 80s vintage. Some cannot be modified by Leica with the 6 bit coding, and a few that can at extremely high prices. So I decided to try the jinfinance mounts.
Their mount for the 90mm Elmarit-M works great. I filled in the ports with the correct code using Testors model paint and the lens automatically is seen by the M 240 and M8.
However, I also order two mounts which are sold for the 135mm Tele-Elmar-M f:4, which I have. The fixing bolt pattern is the same as for my Elmarit-M 1:2.8/21. These two mounts need just a bit of filing to get them to mount smoothly on the cameras.
The 21mm lens, with its original mount, marked with the M-Coder, does correctly communicate with the camera bodies. But when I install the jinfinance mount the camera says "no lens connected".
The 135mm lens has a mounting screw right in the middle of the section where the 6 bit code would be. The jinfinance mount eliminates that screw. But I can't get the lens to be seen by the camera, either with its original mount marked with the M-Coder or with the jinfinance mount.
What could I be doing wrong?
hi john
if i remember correctly, the coding is ''accepted'' by the camera when the code AND the correct frameline for the code is showing. if the original flange brings up a different set of framelines than the jinfinance flange, that might be your problem at least with the 21mm lens? and therefore path to a solution.
greetings from hamburg
rick
re 135mm, is there now a code for this lens? i could be wrong, but at least in m8 days, i think there wasn't a code because the 135mm focal length wasn't ''recommended''. the 135/2.8 had a code because it brought up 90mm framelines.
rick
The code I used for the 135 f:4 lens I have is the 135 f:2.8 code.
The original mount on my 21mm f:2.8 brings up the 90mm frame lines on my M4.
The jinfinance mount for the 135mm lens brings up the 35mm and 135mm frame lines on my M4.
Perhaps I should try to modify the mount I want to use on the 21mm lens to bring up the 90mm frame lines? Is that possible?
Thanks
My three Jin flanges for 35-50-90 come up fine on the m9 but none will read on the m240 which seems much more finicky in reading the 6 bit coding
I wonder if the type of paint used matters. The Testors is glossy. I don't have any Leica coded lenses. Do they use a glossy paint or matt?
Thanks
John
Some ideas for you:
* The frameline pairs are normally 28mm + 90mm; 35mm + 135mm; and 50mm + 75mm.
* I looked here http://www.l-camera-forum.com/leica-news/leica-lens-codes/ for a 6-bit code for your 135/4 but couldn't find one. Have you looked for the 135/4 setting in your camera software?
* The 135/2.8 code can't work with your f4 lens because the 2.8 lens brings up the 90mm framelines.
* My factory coded lens seems to use matt paint.
regards
Rick
When I coded my 21mm f2.8 (the first version of this lens), I ordered the wrong flange from jln. It had the correct hole pattern, but the wrong frameline selector, so the lens was not recognized. When I ordered the correct flange, it worked fine. I used matte paint.
I use Rust-Oleum protective enamel....flat black and flat white. I've coded both a jinfinance mount and Zeiss Zm lens. Worked great. Just make sure to paint both the black and white bits.
Simplygood - did this work on the M240?? Thanks, Larry
