Nikon S to Leica M adapter advice needed.
mangopen
Hi there. I hope this on the right forum- apologies if not, newbie here. Would anyone be kind enough to suggest appropriate adapter(s) for the Nikon Nippon Kogaku S C Nikkor - 5cm f1.4 lens for use on the Leica M bayonet mount. My research so far has produced conflicting reports- iI have seen on some sites that Contax RF adapters should work. Any advice with or without links to such products would be appreciated.
The Amedeo adapters are indeed the best. Stay away from "Kipon" branded adapters - they are terrible.
If you buy an adapter with fixed M mount, pay attention for which focal length pairs it is made (28/90 or 35/135 or 50/75) and buy the one you plan to use a lens for.
There are lenses which cannot be adapted as of their design with large optical elements and alike.
One example is the 35/1.8 Nikkor which has simply a too large rear element to fit physically in an adapter.
Inform yourself first before buying - on RFF (rangefinderforum.com) there is an extensive thread which lenses are confirmed to be adaptable and which not - google for this thread, it's very informative.
Menos, very true re: Kipon adapters. I had two of them and had no luck with the adapter to get the infinity positioning on my Leica. Amedeo is a precise adapter and works well with all longer RF Nikkors.
I had no experience with the 35/1.7, unfortunately. Heard a lot of praise.
And I agree the RFF is a well of knowledge.
Mangopen,
The adaptors made by Amadeo Muscelli are indeed the best available and are superbly designed and engineered hence the high price but in my opinion they're worth it. Amadeo is a Venezuelan who hand makes the adaptors himself. You can buy directly from Amadeo's website and I've always received excellent service.
A word of caution: make sure you order a Nikon S to Leica M adaptor but not a Contax to Leica M adaptor because the Nikon S and Contax mounts had different thread pitches and you'll have difficulty focussing your lens with the wrong adaptor.
(For full disclosure I am merely a happy customer and in no other way connected.)
Pete.
