Using Leica wide angle lenses on a Sony ar7
Guest NEIL-D-WILLIAMS
although I have had no personal experience with the Sony A7 or A7r, what I have read in reviews and foruns and everything alike is mainly 2 things:
- lenses wider than 35mm do not perform so well on the Sonys;
- the A7r has several problems (including the vibration caused by the shutter) that the A7 seems to not have, I am not sure if this is caused by the shutter itself (it clacks twice on the A7r and once on the A7) or because of all the extra resolution of the sensor, or maybe both.
So beware, if you intend to use wide lenses and if you're looking for the A7r, do spend some time reading all that you can find on the net about it and third party lenses before you buy. Or buy in a place that you can send it back if you don't like it. :)
Or consider a used M9 since they are getting cheaper by the day.
  • Replies 51
  • Created
  • Last Reply
If you read all the BS on the Nikon and Sony forums about all the MAJOR issues with the Leica M240 and Leica T then you wouldn't buy either of those as well. I like posting on forums to get the feel for what is new in the market but at the end of the day you have to make your own mind up and try out new things by yourself.
Your statement above has no merit as YOU have only passed on what you have read on the net and have zero experience with any of it.....but thanks for the info anyway :)
I knew I would get bashed for this :) and of course you are right since I am not speaking from my own experience and therefore anything I say about this may be proven wrong.
But my point was just that if everyone says more or less the same things when reviewing the cameras with third party lenses, specifically Leica lenses, then it is fair to say that there is probably some truth about it, at least I like to think that if I am driving and see everyone in the opposite way then probably I am the one who is wrong and not the other way around.
Take it with a grain of salt, try it for yourself if the store offers to refund you if you're not happy, sure, but a little research can save you some future headaches as well and the research I did about Sonys and Leica lenses all returned some kind of 'meh' and specifically when using lenses < 35mm FOV :)
For this reason I went for a used M9 instead of a new Sony.
Away to try this combo out today
BTW, the WATE 16-18-21/4 works just fine on my A7R.
I have experienced shutter vibration primarily in portrait orientation with tele lenses, such as the APO-R 280/4 and Vario-Elmar 105-280/4.2 for certain exposure times. Using landscape orientation and a firm grip with my hands on a tripod seems to work fine.
It's a Leica M Wide Angle Tri-Elmar 16-18-21 mm f/4 lens.
Thanks k&h I will see if I can get one.........Are they a new lens or will I need to buy a second hand one?
Neil,
K-H is right --- the WATE (being a retrofocus design) works great on the A7r. So does the MATE (28-35-50 Tri Elmar (out of production).
Some of the other wide-angle Leica lenses create problems on the Sony due to the close distance between the lens and the camera's sensor (apparently light rays coming from the rear of some lenses -- particularly the small rangefinder lenses -- are too oblique and the sensor is not corrected for this).
I had the A7r but ended up selling it, but not because of any wide angle or shutter shake issues; I couldn't stand the menu interface, spotty AF and the loud shutter. With most lenses fitted I've also found the overall difference in size between the M and the A7r to be nominal.
Have fun!
First try with the Noctilux...........forgot to take the 21mm Lux with me today so will have to wait until tomorrow
but most of what you read on the net is either:
1 hearsay, like yours
2 'tests' by people who dont know what they are doing
3 'tests' in circumstances inappropriate to normal use of the lens.
it wouldn't take much of a search of this site to find (in the photo forum, other) a very long thread about this very subject with plenty of discussion and many examples, thanks in particular to polygamer and Thomas Chen, to show EXACTLY how the a7/r handles leica m wide angles.
Gerry
Gerry
+1 .....thanks Gerry
Lets see how the upcoming a7s does. Silent electronic shutter, and the 12 mp sensor MAY do better with wides.
Btw the voigtlander is acceptable on the edges on the a7r, as has been widely reported.
And the next one, and the next one, and on and on and on.
That Noctilux picture is really nice, great job!
Bob thanks for taking the time to comment. The lighting was not that great and even at 0.95 I still needed ISO 6400.
The biggest thing for me was that I found the Leica lens on the Sony was so much easier to focus with the focus peaking than using the rangfinder :)
