New 35 Summicron and maybe 28 Summilux?
andybarton
Just a reminder that Leica has been known to change the barrels and cosmetics of lenses without actually changing the optics.
- Noctilux f/1 - originally had a separate round bayonet lens hood, later the built-in retractable square hood
- Summilux 75mm - originally had a separate hood and much thinner barrel (lighter weight, too); then a heavier, thicker barrel with a built-in retractable shade; then a minor revision to reduce weight when final assembly moved from Canada to Solms.
- 90 Summicron last pre-ASPH - originally issued with a built-in hood that covered the aperture ring when retracted; later re-engineered with thinner focus/aperture rings, fatter barrel, and a shorter hood to avoid the overlap.
So that might be an all-new 35 Summicron - or it might be the same old ASPH glass in a new barrel, that updates to the current screw-on metal hood paradigm.
Guest Ansel_Adams
Some of the M lenses in the background of that picture are wearing unusual "decoration rings"—i. e. those rings screwed on the lens when the screw-on hood is removed, to protect the threads.
These protection rings are included with the lens in the case of the Summarit-M lenses (instead of a hood which must be purchased as an extra) and the Summilux-M 35 mm Asph (in addition to the hood which is included). But there are no "decoration rings" included with the 21 mm and 24 mm Summilux, Elmar-M 24 mm, Super-Elmar-M 21 mm Asph, Summicron-M 35 mm Asph, Tri-Elmar-M 16-18-21 mm Asph etc ... still, in the picture above these lenses do wear decoration rings—probably custom-made— which give them unfamiliar appearances.
The 28 mm lens next to the Noctilux is just an older non-asph Elmarit-M.
Yes, I think you nailed it. Thy probably jut put the rings on for aesthetic reasons. The focus of the image being the Leica T after all.
I think the point of the photograph is that the new 'T' can use all of Leica's M lenses, whatever their focal length or maximum aperture, whatever their generation, and that the 'T' is the latest chapter of a storied history.
That's why their new 'T' lenses are not the end of the story. Don't like them? Don't want auto focus? Don't buy them, plant a Noctilux on it instead.
