Flange depth
DMJ
Been looking at replacing the flanges on my ZM lenses & I note that the base plate of the ZM flange is slightly thicker than that of the Leica.
I am aware that flange (lens) to sensor distance is important for total frame picture quality, but just wondered if anyone had experience of using a thinner base plate flange on the ZM's, therefore slightly reducing the lens-sensor distance? I am coming up with a scheme to 6-bit code them. If it is important then I will need a shim as well.
Any experience anyone ?
I replaced some Leica flanges with Jinfinance Chinese ebay ones for my wide lenses.
They were .001" thicker and focus was off. I cut them down to the measured original flange thickness and all is well. You will need a micrometer to measure.
I have no Zeiss lenses, but if they are off visually, then there is no chance the lens will focus correctly and I have no idea how a homemade shim could be made to the tolerance required. Further the mounting holes may or may not be placed correctly.
Zeiss M lenses will bring up the correct frame lines and focus correctly. Current models have a recess cut in the flange so you can code with a pen and it will not rub off. Location fixture and pens can be purchased from Pop Flash Photo. $68 last week.
