21mm Summilux vs 15mm/2.8 Distagon
arthury
I already have the 12mm/5.6 VC and the 21mm/2.8 Biogon ZM.
So, those focal lengths and their vicinity are covered.
I may also throw the 24mm Summilux into the mix to consider as I am beginning to see that the 24mm Summilux may be a touch sharper when the subject is closer, just eye-balling the images. But, I guess the 24mm Summilux is not supported by the rangefinder but it also requires an external VF or EVF or LV.
You might be better off renting any lens rather than asking all of us about any number of lenses you desire or are interested in learning about.
Don't think there is much in it, 21mm f1.4 is unique but many different 24mm f1.4s ;-) I rarely feel the need for a lens between 28mm and 21mm
john
Yes, I was just re-reading Erwin's Compendium and he did published from his test results that the 21 'lux is higher contrast and has more sustained micro-contrast than the 24mm at closer distances.
Need to read more.
Need to read more.
Keep in mind the 21 lux is a big animal. Read and rent.
Thanks for the suggestion.
I have the Noct f/0.95 and I know how fingers can get cramps holding an M9 or M240 with a front-heavy lens.
To me it's not as front heavy as my Noctilux 0.95, but balances more like the Noctilux 1.0.
Besides Flickr, do you guys know of a good cache of images shot with the 21mm Summilux?
This lens seems so rare, even with posted images on the Internet. Reviews are also rare compared to the Noctilux. A casual search showed around 10 reviews for the Noct but there under 3-4 for the 21mm.
Have you looked at pbase.com? You can search for images based upon lens type.
Sent from my iPhone using Tapatalk
Just tried it with the search string "21mm Summilux" and came up with only one image and it was about the lens on a camera. :)
I have even gone over to LFI to look. There were some but not a lot.
Owners of the 21mm 'lux, where are your images which you've always wanted to show off? :D
May I see them, please, so I can drool all over my monitor?
You're looking in the wrong place.... Click on the 'cameras' link on the home page, then choose Leica, then scroll down to the Summilux 21mm. Or click Leica Summilux-M 21mm f/1.4 ASPH Lens Sample Photos and Specifications
Only 52 photos, but better than 1 :)
