Flows...1
newnew
Thanks for your comments.
Paul,
Thanks for your comment and suggestion about the cropping.
In that case, I believe the mass balance of the picture will be spoiled between the "static" areas (pebbles) and the "dynamic" areas where water brings a painterly effect in lighter tones. This effect is stronger on the closer areas where the speed is more perceptible.
I understand it is difficult to see all this in the small web picture.
I have printed a bigger version at home which I believe, is more satisfactory for supporting what I wrote above.
I really appreciate your open comments on this.
Ali
Gianluca,
Thanks. I must confess it is all experimental. :o
I was trying to capture the violence of the smallest water movements and contrast it with the static of the what remains on the shores.
I also like this picture and no 3 most.
