colonel
Two lens kit travel combo
This is my asinine question for the weekend, but a real one for me as I build up a lens kit for my M240 (previous Leica kit was sold - silly me, anyhow move on ....)
35mm f1.4 FLE + 75mm f2.5 - will I miss the 50mm ? the best compromise between DOF play and a wide angle of view ?
24mm f2.8 + 50mm f1.4 ASPH - sometimes 35mm can be a partial substitute for both and can be carried around on its own ?
35mm Summicron + 50mm f1.4 ASPH. Two different walkabouts for different days and moods.
With all of these I would get an R adaptor and an R 180mm f3.4 APO for long telephoto work, but would not walk around with this lens - special events only.
thanks in advance
Edited by colonel
Share this post
If I was going on a trip and could only take two lenses I think today I would grab the 28 Elmarit ASPH and the 50 Summilux ASPH, but I would struggle not to take the 35 FLE instead of the 28 as it's my favorite lens and different enough from the 50 to nicely compliment it. However I've grown to love the little 28 Elmarit ASPH these past few months, and for travel it's just such a perfect balance of size and performance in an economical package. Also the 28mm focal length is just so practical for travel, as you can get in close for street or step back for architecture.
Share this post
Tri Elmar 28/35/50
Tri Elmar 16/18/21.
Two lens travel kit.
But then we'd probably see another post about adding a 24 vs 75.
I don't understand these types of threads, especially from experienced M users.
Jeff
Share this post
To add to Stephen's comments on the 28/2.8, also one can step back for landscape or even if in a tight city it is a good lens to have.
Stephen, what happened to your 21/3.4?
Edited by algrove
Share this post
To gauge other opinions.
I typically try for one lens for a challenge. With 2 lenses the danger is ending up only using one so the other becomes a dead weight.
Share this post
If I had to pick one lens for walk-around I'd go for the longest focal length I could possibly get away with and that typically for my work - think dingy narrow alleyways - would be 35mm. Which 35mm, well, what is there that's better than the 35 Summilux ASPH FLE?
The fact is I also need a much wider lens for architectural based tripod work, and again, what is there that's better than the 21 SEM?
Add a short tele and I'm done.
Above all, be sure to choose the focal lengths you need rather than those recommend by others.
Share this post
With all of your photographic experience, with many marques of camera, you surely must know which focal lengths will meet your travel requirements. It is very subjective.
I like going with one or two or three lenses, depending on subject expectations. But like many I have a wider choice of options so that the combinations can be tailor-made to suit the occasion and my changeable inclinations. I guess I am not alone in approaching travel photography in this way.
Share this post
Depends on where you are going. (Well, actually it depends on many factors as we all know ... but it is fun to talk about and we are often confronted with this decision.)
For landscape destinations. Recently I took photos in the snow-covered alps with a 35 Summilux (for indoor and night shots; Christmas stalls etc.) and a 75 for landscapes. Worked very well although I would have preferred 28 rather than 35 for the panoramic landscapes. The best photo from the trip was taken with the 35.
For city visits I usually take Stephen's suggested combo 28 Elmarit (tiny lens for walking around; nice and sharp for architecture) and 50 Summilux (people; selected visual details)
Share this post
I love the 21SEM and use mine often, but for a two lens travel kit it's a bit specialized.
Share this post
I recently travelled abroad and took 3 lenses with me. Never took the 35 FLE off the camera. This isn't a 35 FLE plug...a plug for traveling with one lens. As a photography teacher I respect said: "If you travel with one lens, the right lens is always on the camera. If you travel with more than one lens, the wrong lens is always on the camera."
Share this post
Guest Marc G.
I'd probably go for something unusual. 21+75 would do for my purpose if I'd start from scratch. With my current lineup 21/28/50/90 I'd either go 28/50 or 21/90, depending on the destination
Share this post
My customary 2-lens travel kit is comprised of 28 and 75 'crons; find this works well for me. These on an M9. If considering an M8-equivalent crop factor and the M9 "full frame", this works out to effective FOV's of 28, 35, 75, and 90.
Share this post
i myself can never part with the 21 SEM! Small and a superb performer. If you are a fan of wide angle perspective and its effect, look no further!
then for a second lens, i usually go with 35 or a 50 depending on the country i'm going to. For a cramped, highly populated city like Tokyo, i bring a 35mm etc.
those are my go-to lens while travelling light.
Share this post
For me it would definitely be the 50 lux and 28 cron. Personally I do 90% of my work with these 2 lenses
have you tried working with a 35mm ? or always used a 50mm
Edited by colonel
Share this post
Loading...
    No registered users viewing this page.
