Leica 50mm summarit 2.5 vs 50mm summicron M
stump4545
Which 50'cron?
- Leica Summicron-M 50mm f/2.0 - Collapsible (1952-1960)
- Leica Summicron-M 50mm f/2.0 - Rigid (1956-1968)
- Leica Summicron-M 50mm f/2.0 (1969-1979)
- Leica Summicron-M 50mm f/2.0 (1979-Now)
- Leica APO-Summicron-M 50mm f/2.0 ASPH (2012-Now)
Just received a sample of the 50/2.5. Looks as sharp as the current Summicron at first glance with perhaps less CA. The focus tab with short focus throw works fine if you like that and the lens is significantly shorter than the current Summicron. No experience enough to tell more for now.
true, but I found the elmar a little harder grip when focusing.
I like the summarit I lot since it is smallish, but the cron is a little nicer to focus with imho.
wasnt sure if the summarit flares less then current non apo 50mm cron.
Yes the Summicron with the built-in hood flares more than the Summicron of the same build with the separate hood and it could well be that the Summarit flares less because it has a better hood. However, the Elmar has not a very effective hood but I never saw it flare.
any advantages the current 50mm summicron non apo have over current 50mm summarit besides 1/2 stop speed?
I bought both and returned the Summarit, mostly for the convenience of the built-in hood on the Summicron and the 1/2 stop.
Summarit is a bit more flare resistant without the hood, about the same with. Summarit has slightly smoother bokeh most of the time, but when the Summicron's bokeh is good, it is VERY good, just a bit more unpredictable.
Honestly, if you don't care about the 1/2 stop, save your money and get the Summarit. It is outstanding.
FWIW, I made the opposite choice with 35mm and chose the Summarit over the Summicron. The 35mm Summarit has even better bokeh than the 35 Cron "Bokeh King". I also own the 90mm Summarit, so its safe to say that I'm a fan of Leica's "budget" line.
I have had both. Both are great lenses.
Advantages of the summicron:
- f/2 against f/2.5
- build in hood against separate 120 euro hood
- 0,7m minimal focus distance instead of 0,8m
Advantages of the summarit:
- price
- focusknob
- smaller size
In optics the differences are small and the choise is personal.
I like the semi classic look with more busy bokeh of the summicron better. The summarit gives a more modern, cleaner look.
Overall, the optical performance with the f/2 and the 0,7m made me choose the summicron.
LOL! Good question, did you ever read wine descriptions?
You'll know good bokeh when you see it. And you'll see a lot of it in close ups of actors in well filmed movies. But bad bokeh is almost invisible... like something that is not quite right but you can't put your finger on it.
Bokeh is more of a factor in lenses over 50 mm and much less of a factor in wide angle lenses. If you like to set your 35 mm lens at 5.6 and pre-focus it for 5 meters, then bokeh shouldn't be in your dictionary. On the other hand, if you just dropped over $4,000 for a 50 Summilux ASPH or 75 Summicron to shoot wide open, then the nature and character of bokeh is part of your style... your signature.
