ritomo Posted April 18, 2007 Share #1 Posted April 18, 2007 Advertisement (gone after registration) Hello CV15mm users, I made an L/M mout adapter for the CV15mm. 1, Cut off the part over code sencer of the lens mount. 2, Make a tab from 1mm nickel silver board. 3, A tab glued by a super glue. 4, a black cord by black marker. Using a profile of WATE 16mm, the cyan drift was disappeard. Thank you. T.Kuwahara Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/21789-cv15mm-iruv-cut-filter-firm-1102/?do=findComment&comment=231773'>More sharing options...
Advertisement Posted April 18, 2007 Posted April 18, 2007 Hi ritomo, Take a look here CV15mm + IR/UV cut filter + firm 1.102. I'm sure you'll find what you were looking for!
Guest Arias Posted April 18, 2007 Share #2 Posted April 18, 2007 How did you fix the filter to the lens? H. Quote Link to post Share on other sites More sharing options...
atufte Posted April 18, 2007 Share #3 Posted April 18, 2007 Looks great, this will probably be my way out of the cyan drift problem aswell, since i got the same adapter for my CV15... But one question, did you glue the coded metal part to the adapter, if so how ridgid is it...? The coded metal part is it aluminium, or stainless steel..? Thanks for this great idea... :-) Quote Link to post Share on other sites More sharing options...
jaapv Posted April 18, 2007 Share #4 Posted April 18, 2007 Looks great, this will probably be my way out of the cyan drift problemaswell, since i got the same adapter for my CV15... But one question, did you glue the coded metal part to the adapter, if so how ridgid is it...? The coded metal part is it aluminium, or stainless steel..? Thanks for this great idea... :-) The mount is copper, so if you use a similar material for the tab, you must be able to solder it. (and file it flat of course). If you do not plan to ever remove the adapter you can even superglue it to the lens for stability. A very good idea by ritomo Quote Link to post Share on other sites More sharing options...
egibaud Posted April 18, 2007 Share #5 Posted April 18, 2007 as soon as you can make the coding "fixed" not a sharpie version, let me know how to send you money so I can place your first order I am serious about it :-) Eric Quote Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted April 18, 2007 Share #6 Posted April 18, 2007 I love this alternative stuff, awesome Quote Link to post Share on other sites More sharing options...
jlm Posted April 18, 2007 Share #7 Posted April 18, 2007 Advertisement (gone after registration) against my better judgement perhaps, but I am considering manufacturing from scratch a leica-thread-to-leica-bayonet adapter with machined recesses for self-coding. probalby would sell in the $140 range... it would primarily be designed for the 15mm Voightlander lens and match that as far as flange thickness, frame lines called up, etc. any interest? Quote Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted April 18, 2007 Share #8 Posted April 18, 2007 LOL I knew this was a matter of time you would do this. BTW folks John made the WATE adapter that is simply brillant in design and manufacturing. Quote Link to post Share on other sites More sharing options...
gravastar Posted April 18, 2007 Share #9 Posted April 18, 2007 Yes If you also made one with a longer stepped flange it could be filed by the user to bring up different frame lines. The steps would indicate how much metal to remove. Bob. Quote Link to post Share on other sites More sharing options...
Venkman Posted April 18, 2007 Share #10 Posted April 18, 2007 John, I'd take one Quote Link to post Share on other sites More sharing options...
ritomo Posted April 18, 2007 Author Share #11 Posted April 18, 2007 Hello All, I fixed the IR/UV cut filter by the O-ring. I thought that it was good that the best method to wipe off the cyan drift of IR cut filtered CV15mm, used a profile of the WATE. Thus I made this L/M adapter for myself. Glueing a cording tub together in L/M maount, I used a superglue, the durability may not be high, but the practical use does not have any problem, I think. Somebody may notice that it releases this L/M adapter with 6Bit cord. I expect it. Regards, T.Kuwahara Quote Link to post Share on other sites More sharing options...
egibaud Posted April 18, 2007 Share #12 Posted April 18, 2007 Hi, YES very interested. send me a private message to tell me where to send you the money :-) Eric against my better judgement perhaps, but I am considering manufacturing from scratch a leica-thread-to-leica-bayonet adapter with machined recesses for self-coding. probalby would sell in the $140 range... it would primarily be designed for the 15mm Voightlander lens and match that as far as flange thickness, frame lines called up, etc. any interest? Quote Link to post Share on other sites More sharing options...
baloo Posted April 18, 2007 Share #13 Posted April 18, 2007 Hi John. I’m interested too! Quote Link to post Share on other sites More sharing options...
scho Posted April 18, 2007 Share #14 Posted April 18, 2007 against my better judgement perhaps, but I am considering manufacturing from scratch a leica-thread-to-leica-bayonet adapter with machined recesses for self-coding. probalby would sell in the $140 range... it would primarily be designed for the 15mm Voightlander lens and match that as far as flange thickness, frame lines called up, etc. any interest? John, I will buy two. Let me know how to order. Carl Quote Link to post Share on other sites More sharing options...
sisoje Posted April 18, 2007 Share #15 Posted April 18, 2007 against my better judgement perhaps, but I am considering manufacturing from scratch a leica-thread-to-leica-bayonet adapter with machined recesses for self-coding. probalby would sell in the $140 range... it would primarily be designed for the 15mm Voightlander lens and match that as far as flange thickness, frame lines called up, etc. any interest? put me down for 2, please... Quote Link to post Share on other sites More sharing options...
Jamie Roberts Posted April 18, 2007 Share #16 Posted April 18, 2007 Me too! (great post, eh?) Quote Link to post Share on other sites More sharing options...
jlancasterd Posted April 18, 2007 Share #17 Posted April 18, 2007 against my better judgement perhaps, but I am considering manufacturing from scratch a leica-thread-to-leica-bayonet adapter with machined recesses for self-coding. probalby would sell in the $140 range... it would primarily be designed for the 15mm Voightlander lens and match that as far as flange thickness, frame lines called up, etc. any interest? Count me in if you would be prepared to ship to UK against a credit card or PayPal payment. Quote Link to post Share on other sites More sharing options...
gdewitt Posted April 18, 2007 Share #18 Posted April 18, 2007 against my better judgement perhaps, but I am considering manufacturing from scratch a leica-thread-to-leica-bayonet adapter with machined recesses for self-coding. probalby would sell in the $140 range... it would primarily be designed for the 15mm Voightlander lens and match that as far as flange thickness, frame lines called up, etc. any interest? Yes, definitely interested! Quote Link to post Share on other sites More sharing options...
dhoelscher Posted April 18, 2007 Share #19 Posted April 18, 2007 against my better judgement perhaps, but I am considering manufacturing from scratch a leica-thread-to-leica-bayonet adapter with machined recesses for self-coding. probalby would sell in the $140 range... it would primarily be designed for the 15mm Voightlander lens and match that as far as flange thickness, frame lines called up, etc. any interest? I sure would ... would be much cheaper than paying super big $$$ on Ebay for the few remaining "old" LTM adapters ... Quote Link to post Share on other sites More sharing options...
Ken R Posted April 18, 2007 Share #20 Posted April 18, 2007 Yes I will take one as well. Makes me think there is a market for 6bit coded adaptors. The first one to get them to ebay will make a killing I would think. Ken Quote Link to post Share on other sites More sharing options...
