maddog88 Posted February 16, 2014 Share #401 Posted February 16, 2014 Advertisement (gone after registration) Hello again, Mark! Just one more thing, I have the flexi clamps but my concern is whether or not I have to remove the mode dial and the ON/OFF switch from the top of the camera in order to be able to lift the top off? Also, will I have to de-solder anything when I lift the top off? I saw in one of your very first pictures that there is a flat cable on the left side of the photo that is being folded away from the top with a metal part at it's end. I am not that good at soldering, that's why I ask. Thanks again Milos Quote Link to post Share on other sites More sharing options...
Advertisement Posted February 16, 2014 Posted February 16, 2014 Hi maddog88, Take a look here Anatomy of the Leica M8. I'm sure you'll find what you were looking for!
marknorton Posted February 16, 2014 Author Share #402 Posted February 16, 2014 No, removing the top is quite easy - remove the 5 screws to release the plastic plate, remove the end screw inside the battery compartment and the screw (which is captive) at the other end. Ease the top off and disconnect the flexprint by lifting the locking levers either side and gently pulling the flex out. As always, you will not need to use any force, work in as dust free an environment as you can find and avoid touching things with greasy fingers. Cloth or latex gloves are good. Make sure you use the correct tools - P000 for the plastic plate screws (which are quite tight) and P00 for the other too. Remember the best way to remove a cross head screw is to use the correct shaped tip and press reasonably hard into the screw while applying torque to prevent the screwdriver riding up and damaging the screw-head. 2 Quote Link to post Share on other sites More sharing options...
maddog88 Posted February 21, 2014 Share #403 Posted February 21, 2014 Hello again, I postponed the action until I clarify one more thing. I have uploaded a photo of the battery compartment to make sure I will unscrew the right one. Is it #1, #2 or #3? THANKS Milos Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/21079-anatomy-of-the-leica-m8/?do=findComment&comment=2536419'>More sharing options...
k_g_wolf ✝ Posted February 22, 2014 Share #404 Posted February 22, 2014 You are very brave, Milos, where is HE, when HE is needed ? Best GEORG 1 Quote Link to post Share on other sites More sharing options...
maddog88 Posted February 22, 2014 Share #405 Posted February 22, 2014 Perhaps you can help, Georg, just pick a number.... I am sure Mark will reply, he must be busy... Sent from my iPhone using Tapatalk 1 Quote Link to post Share on other sites More sharing options...
maddog88 Posted February 23, 2014 Share #406 Posted February 23, 2014 Well, I guess I'll have to unscrew all three and see what happens... or shall I Just drill them out? Sent from my iPhone using Tapatalk 1 Quote Link to post Share on other sites More sharing options...
alex7075 Posted February 23, 2014 Share #407 Posted February 23, 2014 Advertisement (gone after registration) Let's wait for Mark's reply, but having done the thing twice for the very same reason, I think none of these three screws is the right one (my M8 is in Wetzlar right now so I can't show you). You should look for a little hole on both sides of the camera where the screwdriver goes up until it reaches a screw that is directly attached to the top cover. 1 Quote Link to post Share on other sites More sharing options...
maddog88 Posted February 23, 2014 Share #408 Posted February 23, 2014 Alex, Mark said it's the one that goes up on the other side, when the plastic cover is removed, AND one of the three screws in the battery compartment. My guess is the number 3 on my picture, because Mark refers to it as the "screw near the end", but I just want to be 100% positive. And I am doing this on an M9... Why is your camera at Wetzlar (Solms)? Quote Link to post Share on other sites More sharing options...
alex7075 Posted February 23, 2014 Share #409 Posted February 23, 2014 You're right, let's see what Mark tells us, I opened the top some months ago and without the M8 in my hands I am not sure of my saying. M8 plus Noctilux are there for focusing calibration and another old lens for cleaning. Waiting so much to have them back! 1 Quote Link to post Share on other sites More sharing options...
maddog88 Posted February 23, 2014 Share #410 Posted February 23, 2014 Alex, When you removed the top for cleaning, was it difficult to detach it from the bottom? Was it easy to put it back? Please share your experience. Thanks Milos Quote Link to post Share on other sites More sharing options...
alex7075 Posted February 23, 2014 Share #411 Posted February 23, 2014 Alex, When you removed the top for cleaning, was it difficult to detach it from the bottom? Was it easy to put it back? Please share your experience. Thanks Milos Milos, the operation is very simple. The top comes out easily but beware of the circuit which is quite short. I didn't detach it though, because you can anyway turn the top upside down to inspect and clean it. It is quite heavy as Mark points out. I cleaned it blowing some air in the viewfinder and that was ok. Then you just replace it in its position, press it down and you screw again the famous two screws from the bottom! The whole thing took ten minutes. But let's wait for Mark's answer, I am in no way as good and experienced as he is! Quote Link to post Share on other sites More sharing options...
maddog88 Posted February 23, 2014 Share #412 Posted February 23, 2014 Thank you, Alex, I'll try to stay patient and wait for the highest authority on this matter to have his say. Sent from my iPhone using Tapatalk Quote Link to post Share on other sites More sharing options...
maddog88 Posted March 2, 2014 Share #413 Posted March 2, 2014 It looks like I won't be getting a confirmation on the exact screw anytime soon... I re-read Mark's posts again and again trying to figure out what the "end screw" exactly means, whether it is the one towards the rear end or the right end of the camera, but I am still not sure... If I only knew that if I choose to unscrew the wrong one, I won't be doing something fatal to the camera, I'd go for it...anyone wishes to comment, please do so before it's too late..anyone? Sent from my iPhone using Tapatalk Quote Link to post Share on other sites More sharing options...
k_g_wolf ✝ Posted March 2, 2014 Share #414 Posted March 2, 2014 Send HIM a PM, HE seems to be a busy man and doesn´t return too often to this site. Best GEORG 1 Quote Link to post Share on other sites More sharing options...
alex7075 Posted March 2, 2014 Share #415 Posted March 2, 2014 Milos, take a look at post n° 4 in this page: it's in french, but the pictures show you exactly how to proceed. summilux.net • Afficher le sujet - Démontage M8 3 Quote Link to post Share on other sites More sharing options...
marknorton Posted March 2, 2014 Author Share #416 Posted March 2, 2014 Sorry, missed this. It's screw 3 you need to undo to release one end of the top cover. There's a corresponding screw at the other end which is captive (meaning it does not come out when undone) and is reached by inserting a long cross-head screwdriver into the hole; you can "feel" for the screwhead with the screwdriver. 3 Quote Link to post Share on other sites More sharing options...
maddog88 Posted March 2, 2014 Share #417 Posted March 2, 2014 Thank you Alex and Mark! I know I was asking the obvious, but i just had to make sure. I'll post the results when I do it, in a few days.. Quote Link to post Share on other sites More sharing options...
david strachan Posted December 18, 2014 Share #418 Posted December 18, 2014 No, removing the top is quite easy - . An amazing story Mark; congratulations on having such a wonderful forensics brain. I do hope the Mods make this a sticky. cheers Dave S Quote Link to post Share on other sites More sharing options...
Jeff S Posted December 21, 2014 Share #419 Posted December 21, 2014 I do hope the Mods make this a sticky. The thread is almost 8 years old, and you still found it. Jeff Quote Link to post Share on other sites More sharing options...
Doc Henry Posted December 22, 2014 Share #420 Posted December 22, 2014 Jeff, no need Mark became now a legend Just enter "anatomy M8" on Google and you will see In passing , very good Leica digital camera , CCD quality , may be the best ! Best Henry Quote Link to post Share on other sites More sharing options...
