Einst_Stein Posted July 29, 2013 Share #1 Â Posted July 29, 2013 Advertisement (gone after registration) I have seen Visoflex lens to Hasselblad V camera adapter but no Hasselblad V lens to Visoflex. Â Hasselblad V flange distance is 74,9mm, Visoflex plus M camera body flange distance is 68.8mm (41mm + 27.8mm). A Hasselblad V to Visoflex adapter should have Hasselblad V mount on the lens end and M mount on the camera end but with 6.1mm distance in between. Â Am I right? Is it possible? Anyone has seen it, where to buy? Link to post Share on other sites More sharing options...
Advertisement Posted July 29, 2013 Posted July 29, 2013 Hi Einst_Stein, Take a look here Adapter for Hasselblad V lens to Visoflex. I'm sure you'll find what you were looking for!
luigi bertolotti Posted July 29, 2013 Share #2  Posted July 29, 2013 Your computation is right: it is possible, and Forum Member Lindolfi did make one in house : http://www.l-camera-forum.com/leica-forum/leica-m-lenses/250851-use-hasselblad-lens-leica-m-camera.html  Novoflex does list two rings (LEMA + HARING) which, when coupled, have a M male bayonet at on side and a Hasselblad V female at the other, but I don't know if the total length is such to achieve a correct focusing on a Visoflex. Link to post Share on other sites More sharing options...
alfa117 Posted August 23, 2013 Share #3 Â Posted August 23, 2013 The NOVOFLEX adapter ring combination LEMA + HARING only works with Leica M cameras and Hasselblad V-lenses. The Visoflex II/III-reflex housing can't be used with it... Link to post Share on other sites More sharing options...
