skinnfell Posted July 19, 2013 Share #1 Â Posted July 19, 2013 Advertisement (gone after registration) There is much talk about front focus and back focus, etc. What I dont understand is how a lens can drift over time. My favorite lens, summicron 50/IV, started out being perfectly calibrated and is now WAY off. Judgning from my files throughut the last couple of years it has gradually become more and more erroneous. I have tried it on several different cameras and it behaves the same, likewise, my other leica lenses do not have this. (It is now on its way for a Spa in germany, and I suspect it to be an expensive one.) Â Does anybody have a good explanation to why focus drift happens? Are there any measures one can take to prevent or alleviate this? Â Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted July 19, 2013 Posted July 19, 2013 Hi skinnfell, Take a look here Understanding focus drift. I'm sure you'll find what you were looking for!
lct Posted July 19, 2013 Share #2 Â Posted July 19, 2013 It might be that your lens was off from the beginning but you did not notice it on film. Digital is less forgiving. Now i have a 50/2 v4 that i bought new 30+ years ago and it has no focussing problems on my digicams so far (R-D1, M8.2, M240). Link to post Share on other sites More sharing options...
AncientCityPhoto Posted July 19, 2013 Share #3 Â Posted July 19, 2013 This happens to all equipment with use over time. Bumps, mounting and dismounting of lens, bouncing around in camera bags, etc... Some times its more noticeable than other times. I get my rangefinder equipment checked every year. My dslrs get checked yearly too. With rangefinders, it seems its the actual rangefinder that falls a bit out of calibration more often than the lenses them selves. Link to post Share on other sites More sharing options...
jdlaing Posted July 19, 2013 Share #4 Â Posted July 19, 2013 I believe focus drift is more prevalent in zoom lenses and focus by wire lenses rather than fixed focal length prime mechanical lenses. Â I too think the rangefinder mechanism is easier to drift off than the lenses. Link to post Share on other sites More sharing options...
TomB_tx Posted July 19, 2013 Share #5 Â Posted July 19, 2013 For lens focus to change there must develop a difference between the optical cell position and the RF cam. There are different designs for establishing the relationship, but most Leica lenses are fixed so that I wouldn't expect changes. I have had a lens group loosen and cause changes, but that affected overall performance as well as focus position. I believe some other brands of M-mount lenses use set screws to secure the focus adjustment, and this would be more likely to loosen and shift, but I wan't aware of Leica using this method. Link to post Share on other sites More sharing options...
Michael Geschlecht Posted July 19, 2013 Share #6 Â Posted July 19, 2013 Hello skinfell, Â There is another possibility, depending on what you mean by 50/IV. Â If you mean the first version of the 6 element 50mm Summicron that replaced the 50mm Rigid: Then there is the possibility that some of the earlier production pieces might have been made with divisible lens mounts for use in making close-ups. As per the preceding 50mm Rigid model. Â If that is the case then simply tightening the lens head to the lens mount might solve your problem. Â Best Regards, Â Michael Link to post Share on other sites More sharing options...
TomB_tx Posted July 19, 2013 Share #7  Posted July 19, 2013 Advertisement (gone after registration) If you mean the first version of the 6 element 50mm Summicron that replaced the 50mm Rigid: Then there is the possibility that some of the earlier production pieces might have been made with divisible lens mounts for use in making close-ups. As per the preceding 50mm Rigid model. Best Regards,  Michael Michael: that is correct. The 6-element version I bought in 1969 was from the first production batch in 1968. The lens head unscrews just like the "rigid" version. That construction makes it easy to shim to correct a rear focus error, but not so simple for front focus. I believe these were still made where the focusing cam was finish-ground to profile to match the exact assembly. Mine does front-focus a bit at f2.0, but shifts to exact focus between f2.8 and 4.0. (So does my 1962 Rigid - so I wonder if that was normal so that focus shift wasn't all in one direction from perfect.) The v4 (2012) I have is exact at f2.0. Link to post Share on other sites More sharing options...
