50mm and 35mm summarit flare
stump4545
Guest Marc G.
every lens can basically flare. but the summarits are very resistant to flare and some say that the lens hood is primarily for mechanical protection. Of course, the lens hood provides the optimum so I would take it just to get the personal safety (having done everything possible to prevent flare...). the hoods are very well made and are still fairly small... if you own one already, just take it with you. shouldnt add too much weight & bulk
Don't believe everything you read, except on the internet of course :D
I have both 35 and 50 Summarits.
When the sun is in the image I find it hard to make them flare.
However, when the sun hits the front element at a slant angle, they tend to flare more than I like.
So I always use the shade, and even then.....
Hope this helps,
Guest Marc G.
screw-on seems a far better design than clip on. those clip on hoods often are held via metal "claws" which often scratch the lens barrel when removing and attaching the hood. doesn't happen with the summarit hoods. only thing worth thinking about would be some sort of stronger attachment to the hard stop so the hoods dont screw loose that often
Much worse, you risk that the lens hood loosen and vignette the image.
As the hood is visible in the viewfinder you can see that it rotated when you compose your image.
As far as I am concerned this is a total non-issue.
