Jon Pop Posted May 27, 2013 Share #1 Posted May 27, 2013 Advertisement (gone after registration) I'm planning on getting an extension cord for my flash for use of the flash off-camera with my M9, but I also like to use a 28mm external finder which is in the hotshoe. What's the best solution, are there other cords that allow for this? Looking at the Nikon SC-28 it doesn't look like it, but I'd welcome advice. Apologies if there's already a ton of threads on this topic already. Cheers, Jon Link to post Share on other sites More sharing options...
Advertisement Posted May 27, 2013 Posted May 27, 2013 Hi Jon Pop, Take a look here M9 + External Finder + external flash question. I'm sure you'll find what you were looking for!
ghoonk Posted May 28, 2013 Share #2 Posted May 28, 2013 The M9 already has 28mm framelines, so I don't usually use an external finder for it, hence no issues using it with wired or wireless triggers Link to post Share on other sites More sharing options...
Jon Pop Posted May 28, 2013 Author Share #3 Posted May 28, 2013 I know it has 28mm frame lines...as does my MP and the M6TTL I had for years before that. I'm not new to Leica M; but I wear glasses,the lines are at the far perimeter, and I also want the ability to see the composition thru a 28mm point of view. Same rationale as when I shoot 21mm.....where the finder is mandatory not optional.... Link to post Share on other sites More sharing options...
Adonnan Posted May 29, 2013 Share #4 Posted May 29, 2013 Since there is no sync port, I don't see how you could have both. Unless there is a hotshoe spacer that adds a sync port. I made that up Link to post Share on other sites More sharing options...
