I have the ZM 4.0/85 Tele-Tessar which brings up the 90mm framelines on M9 & Monochrom. After chimping for about ten minutes you fairly quickly learn to frame a bit outside the 90mm framelines.
It's a very nice focal length to use.
Does the M viewfinder have frame lines that will work with a Zeiss 85mm? Will this lens work with the optical rangefinder?
My Zeiss ZM 85 f/2 naturally selects the 90mm frame lines, and I use the manual lens profile of the 90 Summ APO. Everything works beautifully, particularly the images!!
