Advice on a 24mm Lens
Coach Rosie
  • Replies 72
  • Created
  • Last Reply
Are you still looking to sell your 24mm 2.8?
I've just self 6 bit coded it and changed the metal hood for a rubber one I can pull off when not needed, so I am resigned to keeping it.
Selling Leica lenses is a bit like giving away your children ...... I almost invariably regret it so I'm hanging on to all of mine unless starvation forces me to part with them....:rolleyes:
Better than the newish 24/3.8? And how about the 24/1.4?
I like the 24mm view, a wide view that seems 'natural'. Used it on an R4 so when the focal length became available for the M I bought the elmarit just after it was introduced. Its a great lens optically but for some reason it just never 'felt' right. Looked at the Elmar and liked its size, but just not fast enough for an all-around lens.
Have had the 24 Summilux now and although it seemed too large in paper it handles very well, balances nicely on the camera, and with a beautiful image quality. Just as good as the Elmarit at 2.8 but better at f1.4-f2 ;-)
...and bought the 24/2.8 Elmarit in 2006, then bought another one two years later because I love the focal length so much. To me so much more usable than the 21. ...
Exactly my opinion as well. A 24mm lens, if used right, gives a lot of coverage without screaming out "wide angle" all the time. Simply a great lens!
Andy
All of these lenses are good. But for me, the Summilux was too big/heavy and I don't need f1.4 on a lens that's verging on a super-wide. The Elmar is nice and small and I only took a small number of shots with it but I just prefer the way the Elmarit renders. I think maybe the Elmar is a bit sharper but that's not an issue for me I'm more interested in the way a lens draws. I've had the Elmarit for a fairly long time and it's looking a bit worn but I'm very comfortable with it and I'm probably biased because of that.
Yes, #11648. Are you then saying that the code for the 24/3.8 should be manually changed because you prefer the Elmarit code for it? I never dreamed of changing a 6 bitted lens manually to another code. Perhaps a good idea. But why? Maybe I missed your explanation earlier.
Exactly. The Elmar's own profile vastly under-corrects the vignetting. The fact that according to Leica's data sheets the vignettings of both 24 mm lenses, Elmarit and Elmar, basically are equal seems to indicate that there's a firmware error in the Elmar-M 24 mm Asph's lens profile.
I first noticed with firmware v1.162 (which doesn't mean earlier versions were better; I just didn't check), and in the current version v1.196 the issue is still there.
I don't wear glasses (yet), but am amazed how close you get your eyeballs to the finder. :D
I found the Minolta CLE's finder was doing the job ok, but that's .58.
On .72 (M6), already the 28mm frame played hide-and-seek with me. Now, once you get the feel for the lens it probably matters less.
Alexander
…changed the metal hood for a rubber one I can pull off when not needed, …[
/QUOTE]
What rubber hood is that? Interested…
...... well I eventually bought a selection of screw in collapsible ones ... most of which were visible in the corners of the pictures, so I ended up cutting most of them down in an effort to avoid this. The actual problem is the screw in mount that pushes the hood too far forward ..... I eventually hit on the ploy of removing the rubber bit from the mount ...... they usually have a lip that sits in a groove in the mount. This is just about the right size to fit in the groove that the original metal hood fits in on the 24..... so I just pull the rubber hood over till it locks into position. Can't recall what size fits best but it needs a bit of stretch to stay in place. When off it can be folded/stuffed anywhere.
Anyway, I can't abide lens hoods unless they are really necessary, and here in the UK we get so little sun that you can live without one most of the time.... so most of my bigger metal Leica ones are in a box.
Same trick works perfectly for the MATE, and I have a fixed rubber one instead of the disastrous scratching contraption that came with the 90/4
Opposite here in the sunny Antipodes :), except for today (cloudy & raining) when I wanted to go out to do some photography:mad:)
I very rarely go out without the lens hoods fitted, although I also like them for the protection they offer the lens.
