Leica R lens and NEX7
dierk
Is NEX-7 the best (low cost) option for R lenses? How about NEX-5n?
I started with the NEX-5N. Later, I bought the NEX-7 as well. Both were second hand items, so I can't tell anything about prices.
Here are some of the differences between the cameras which I personally found relevant:
[b]NEX-5N[/b]                                  [b]NEX-7[/b]
smaller case                            larger case (wider)
difficult to use with gloves            easier to handle with gloves
I keep on pressing unwanted buttons)     I still press on video rec button
external EVF                            EVF built in
EVF articulated (tiltable)              fixed position
fewer controls, overloaded              two extra thumb wheels for selectable settings
will not fit into bag with EVF mounted  fits into small hadley bag
I just bought two R lenses (21-35 and 28-90) and an R6 - I already had the 80mm. I am also considering to have a digital camera to use them. Is NEX-7 the best (low cost) option for R lenses? How about NEX-5n?
Congratulations on your 21-35 and the 28-90 mm, I have both these R lenses and are beautiful for Digital use.
Personally I wouldn't bother with mirrorless cameras, these R lenses are big and heavy especially the
28-90mm, R lenses where designed for SLR use not puny little toy cameras
IMHO I would recommend either a Canon or Nikon, however both are not perfect.
If you select the Nikon, you need to change the Mount.
Or if you select the Canon EOS system, all you need is a simple adapter, I use the Novoflex which is
Excellent and I can still use my R lenses with my Leica R film Cameras.
Due to the Lens shroud on the back of the 21-35 and the 28-90 it will prevent you from using these lenses
Without hitting the mirror on the full frame Canon 6D or 5D-3 which is a pity, so only the 1.6 crop factor DSLR are useable.
At this time I am using the Canon 600D which I have found it very good and it's relatively cheap, actually it's now cheaper then the Leica EVF module.
Another option is to try them on the Leica M240, no doubt this could be an excellent choice, as I havn't
Tried this combination I cannot comment on it, but the M240 was designed to couple up to R lenses.
Good luck.
Ken.
NEX-5N has less red cast than NEX-7 on some WA Leica lenses (35 mm and lower).
WATE works pretty well on both.
I bought both new.
NEX-5N with optional EVF was similar in cost to NEX-7, but was available earlier.
For standard and longer focal length I prefer NEX-7. For WA the NEX-5N.
NEX-7 has a very nice 2-axis virtual horizon. NEX-5N doesn't.
NEX-7 has 24 MP, NEX-5N has 16 MP.
The combination of R- and M-Lenses with the NEX-7 is giving me great results.
This is a picture of a Grey Squirrel in my backyard, harvesting bulbs.
Apo-Telyt 4/280 + Apo-Ext.2x at f 5.6, ISO3200.
Regards, Ronald.
One more with NEX-7 and Apo-Telyt 4/280 + Apo-Ext.2x, f4, ISO800.
The E-Viewfinder is a pleasure to use and makes focussing safe and easy.
Regards, Ronald.
Hi Ken.Thanks for your recommendations.
I actually had a Nikon D3 which I had sold and moved on to M9 (which I also sold in anticipation for the new M). I still have my complete set of Nikon lenses 14-24, 24-70, 20-200/2.8 that I didn't want to sell just yet. This would make it so easy for me to go back to Nikon DSLR but I want something smaller and easier to carry.
I used the money I had saved up for a M240 when I had the opportunity to buy these R lenses and the R6. It will take me quite a while to be able to afford the new M and meanwhile I want to get a low cost /small size digital solution to use these lenses.
Good luck.
Ken.
