I have to check my blood pressure now
pauledell
My emergency blood pressure checker that I use in a pinch. :D
Paul
Hello Paul,
I hope all is well.
Nice photo.
Could you explain this device please?
It doesn't seem to have the same layout or measure using the same parameters as other blood pressure measuring devices I have seen.
Best Regards,
Michael
Michael,
Its actually a pressure gage for a farm implement. And I am doing well with my BP.
Paul
Paul, Judging from the markings and the numbers, this device reads KPa (kilo Pascal) on the inner scale and PSI (pounds per square inch) on the outer. If you blood pressure reads 3 PSI or 20 KPa or higher, you're in real trouble -- this is over 150 mmHg. Definitely not an accurate device for your BP.
