Using a Thumbs up with a 21mm Viewfinder
Guest NEIL-D-WILLIAMS
i think the framelines are far enough from accurate to make this a non issue ....
No point in adding to the issue then;);)
I use a thrumbs up, but when using a 24 or 21 (my only lenses wider than 28) I simply replace my thumbs up with a Voigtlander 21/25 metal viewfinder.
I did consider another thumbs up with viewfinder mount but looking through the top mounted viewfinder with a thumbs up didnt feel the same and I wasnt sure it added. I did try one out and decided against. Anyhow handholding a 21 at 1/8th is not usually a real challenge
