Am i missing anything here? I bought a soft release for my M9 and it won't fit and I get resistance when I try to install it. I have an M7 and M3 with soft releases too and even if I try to switch soft releases, it still wont securely attach to my M9. What gives?
tobey- I think I am with JB. I got the last of the new Leica M9's. I have 2 other film Leica M's and the softies are working without problem. I think they changed the thread. In any case, i hope the manufacturers make new ones for the Monochrom and the New M's. I would like to hear more from other M users of newer models if they are experiencing my problem and JB. Thanks.
They definitely (!!) did not change the thread.
Doing that would mean that none of the billions of cable releases around would fit.
The thread has always been the same on every camera (from every manufacturer) for the last 70 years.
I'm 100% sure that it's a tolerance issue with your M9.
I found the same problem when trying to fit a soft release button on my Monochrom. This is a machining error as the depth of the thread is too shallow leaving the thread too small at the entry point.
My thoughts exactly! I think they changed something here....
Well, it certainly seems to mess up any use of a cable release.
DOY if you can. If it were deep enough already, I would tap it myself, otherwise drill then tap.
I am pretty sure this is correct (by ISO 6053:1979)
Tap: M3 x 0.5
Drill: 2.50
But not on purpose.
Call Leica and have them replace your shutter release button.
Neither any cable release manufacturer nor any soft button manufacturer will change anything!
Edited by el.nino
Yes, both my Match Tech soft release and my cable release only thread in a very small amount.
Not far enough to stay in.
Tested both with a M6 body today & the thread in properly.
Time to take the MM to the dealer & show them.
I had a Match Technical soft shutter release on my M9-P as well and lost it because of this thread issue. The one on my M8-P has remained on only because I placed a minute amount of small fastener loctite on the threads before threading it on. I seldom if ever use a shutter release cable.
I have examined the internal threads on my Monochrom, M 9 M 8 and M7 cameras and they look to me as if they are tapered. The Monochrom is visably smaller at the entry point. The soft release buttons that I use have tapered external threads as do my cable releases 1 Can the material be tapped by hand safely? 2 Can a taper tap be obtainedto fix this problem? Good luck everyone.
I did read your simple solution but the thread in the stem is taper not straight.Measuring the male thread on a soft release button it is 3.43 mm on the large diameter, 1.65 mm on the small diameter over a thread length of 3.43mm. The spindle rod moves up and down and has a small amount of side movement which would present a small problem to an amateur to tap. Solution, a small amount of thread loctite on the thread or remove the spindle and place in the chuck of a C N C lathe. Program the computer to redrill the thread hole using a taper drill then programming to retap the hole using a taper tap. If these parts were made as a production run on a C N C lathe there should have been no quality problems. Making the parts on an ordinary lathe with no quality control then this type of problem can appear.
So my options are to bring it to a Leica dealer or to tinker it myself? Bringing it to a Leica dealer woudl be my only option as I am not very mechanically inclined to fix the soft release myself. Bringing it to a leica dealer will keep me away from my camera for a good while though...
According to my Leica rep, the shutter button thread was changed slightly with the advent of the M7, due to a number of reported issues of the release plunger pin going too deep and damaging the new style shutter button mechanism.
The current Leica cable release (of course) fits & functions perfectly.
Don't know what I'm going to do about my ill-fitting soft release.
