Sign in to follow this
MRJohn
New M: how about sensor dust and shutter implementation?
Sensor dust:
I really like my M9P but it is a magnet for sensor dust. With the new M I can imagine it can get even worse with liveview. Any information if there is a dust-removal function? Any ideas how much we will have to deal with dust with this camera?
Which brings me to my second question, how is the shutter implemented:
Is there no mechanical shutter blade and the sensor is always visible? Is the shutter implemented fully via the COMSIS sensor, or will a blade shutter kick in with very short shutter speeds? According to the website of COMSIS, the sensor itself must have a shutter function as it can take several hundred images per second for the movie function.
Share this post
Sensor dust:
1. Dust where detected is interpolated out by software (says the specs).
2. There is a metal shutter which is open for live view.
Share this post
Watch Thorsten Overgaard's interview with Stefan Daniel...they go thru these details, including comparing shutter noises, the different ways the shutter works depending on whether live view is on, even the new tripod mount in the bottom (no longer part of the plate but part of the body itself), etc. it doesn't answer all of our questions, but is a pretty good overview and practical. We'll only be able to really know all answers once they start shipping the final products.
It's on Thorsten's website.
Share this post
I see 'Dust detection' in the PDF 'technical data' sheet - no mention of 'interpolated out by software'.
My M9 does dust detection quite well - when there is dust on the sensor, it puts big blotches in my photo to help me locate the dust.
-robert
Share this post
Thanks for pointing out the video from Thorsten, indeed there is a lot of information in there.
Share this post
Loading...
    No registered users viewing this page.
  • Similar Content
    • By onasj
      With the important caveat that this post is largely speculation, let's anticipate the performance characteristics of the M10-R sensor.
      The Leica S3 sensor is 45x30 mm (1350 sq mm) and the DNG files are 9816 x 6512, for a total pixel count of 63,921,792 pixels, or 47,349 pixels per sq mm
      The Leica M10 Monochrom sensor is 36 x 24 mm (864 sq mm) and the DNG files are 7864 x 5200 = 40,892,800 pixels, or 47,330 pixels per sq mm.
      The pixel density of the two sensors is so similar that I assume the discrepancy comes from non-scaling edge usage factors, and/or small 0.01 mm-scale rounding errors in sensor size.
      So if we assume that the S3 sensor and the M10 Monochrom sensor come from the same process, differing only in size and the presence of the Bayer color filter array in the former, then it's reasonable to assume the M10-R sensor also comes from the same process, and is basically a 36 x 24 mm crop of the S3 sensor (as others have hypothesized in this forum previously).
      If this reasoning is correct, then you can expect the M10-R sensor to be the same as the M10M sensor, plus a Bayer CFA, and to perform more or less the same as the S3 sensor on a per-square-mm basis.  Therefore, I would expect:
      - DNG files that are 7864 x 5200 = 40,892,800 pixels
      - Dual gain design
      - 4.6 µm pixel pitch
      - Base ISO = 100
      - ISO range = 100-50,000 (basically one stop lower than the 160-100,000 ISO range of the M10 Monochrom, as one might predict from the lack of the Bayer CFA in the M10M)
      - 14 bits per pixel
      Good ISO 12,500 photos and decent ISO 25,000 photos would be terrific, and a significant improvement over the M10/M10-P, as noted here:
      https://photorumors.com/2019/01/20/mega-shootout-sony-leica-and-phase-one-comparison/
    • By Jonsekulla
      Hi all,
      does anyone know what is going on here?
      All of sudden every photo is like this or a different shape with sometimes a bit of the actual image
      sensor?
      sd card?
      processor?
      any help before sending it away would be much appreciated!
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    • By chris7opher
      Hi Everyone,
      I recently notice a small/short black line at the edge of images taken with M9P. I’m not sure what causes the fault.
      Can anyone please have at these 2 images, and share your thoughts? Thank you.
      - Chris
    • By inkbox
      My Leica D-Lux 3 that displays (1) a purple color shift for white colors in bright light; and (2) a photos show a green or yellow tint in low light.
      I have looked over the presets and defaults. I cannot find a switch that improves the display.
      I believe that the exposure sensor is damaged or malfunctioning.
      Otherwise, the camera is in good shape cosmetically and according to a review of the presets and default, working correctly.
      A used replacement on Ebay is about $150 to $200.
      My questions are:
      -1- Can I send my camera to the Leica repair for a new sensor for that amount of money? I know about the submission form that requires a maximum repair cost to be stated.
      -2- Is a Leica repaired camera totally checked out and then repaired so as to insure long lasting functioning?
      -3- Is it better to purchase another non-leica camera for $150 to $200 with improved specifications like increased megapixels?
      Thanks for reviewing my questions,
      Inkbox
      PS I encountered an error when uploading files; although I deleted the upload files, I cannot upload replacements.
      I have used up all of my storage space and cannot locate a delete button in My Attachments.
    • By goatsby
      I have a M9 that shows signs of slight corrosion and I’ve been holding off on sending it in as the corrosion doesn’t show up under normal shooting conditions. I heard on another forum that  that Leica is planning to discontinue replacing sensors for the M9, is this true? I know supplies must be limited but thought I had another year or so to get the sensor done. Has anyone else heard this?
Important Information
