ronaldh Posted July 21, 2012 Share #1 Posted July 21, 2012 Advertisement (gone after registration) I am having the following problem when importing photos from a card reader into LR4. It is not an issue I ever had when using the same procedures with LR3. I always store photos in one external drive (call it G) and backups in another (H). When importing from the card into my PC I first create a new folder (eg Paris2012) in drive G then another (eg Paris2012.backup) in drive H. I then open LR import module and set the primary import location as Paris2012 in G Drive with a second copy to Paris2012.backup in H Drive. The problem is that as soon as I set the location for the second copy in LR, it replaces the primary location and saves the pictures only in that backup (H) drive. Can anyone help on this please? Link to post Share on other sites More sharing options...
Advertisement Posted July 21, 2012 Posted July 21, 2012 Hi ronaldh, Take a look here LR4 import problem. I'm sure you'll find what you were looking for!
Jeff S Posted July 21, 2012 Share #2 Posted July 21, 2012 You should only need to specify once, in the file handling panel, if you choose to back-up at the import stage and, if so, the location. After that, unless you change something, you should be good to go at each card import. You may or may not choose to keep these unedited DNGs (if that's what you're saving) in addition to the edited files that you routinely (frequency as you specify) back up. Not sure I understand your procedure. Jeff Link to post Share on other sites More sharing options...
ronaldh Posted July 23, 2012 Author Share #3 Posted July 23, 2012 Thanks. I shall try again. Link to post Share on other sites More sharing options...
ronaldh Posted July 23, 2012 Author Share #4 Posted July 23, 2012 Jeff I have re-read your reply but I DO specify at the import stage both the main folder and the backup folder. The problem is that with LR4 (though not previously with LR3) as soon as I specify the backup folder LR re-sets my choice of main folder with the one I have stipulated as a backup. Perhaps it is overkill but my intention is to save the original DNG on two drives but I cannot now do this. Is that clear? Thanks Ronnie Link to post Share on other sites More sharing options...
jaapv Posted July 23, 2012 Share #5 Posted July 23, 2012 So use Image Ingester. Link to post Share on other sites More sharing options...
ronaldh Posted July 23, 2012 Author Share #6 Posted July 23, 2012 Thanks for the suggestion. I'll check that out. Link to post Share on other sites More sharing options...
roguewave Posted July 23, 2012 Share #7 Posted July 23, 2012 Advertisement (gone after registration) Ron. here's a much better workflow. First, make a copy of all the RAW files and place them on an archival drive. It will allow you always make a real copy from the original files. Then make a user copy of the raw file which you import into LR. Once imported, the RAW files will become DNG's, but they will never be RAW files again. I NEVER use my original files, acceot to make another copy. Link to post Share on other sites More sharing options...
ronaldh Posted July 24, 2012 Author Share #8 Posted July 24, 2012 Ben Thank you. That makes a lot of sense. But no-one has explained why I am having the LR import problem! Best Ronnie Link to post Share on other sites More sharing options...
