M9 kit in car trunk
stump4545
I would think it would be dependent on whether you have a bare metal trunk or a lined one, whether your M9 is in a padded bag or just thrown in with the spare tire and golf clubs, and whether you're driving on nice asphalt pavement, or gravel country off-roads......
is it ok to drive with my M9 kit in my car trunk?
In case it´s a LAND ROVER and you put it next to your sparewheel
without a LUIGI-fullcase I would call this a bit daring.
A LEICA-M-camera in a proper padded bag placed in a civilized trunk should be
perfectly allright, even in summer.
Best
GEORG
I would be exceedingly reluctant to do so for several reasons. Primarily I like to have my kit within easy reach for immediate use and for security reasons. If I leave the car, the kit goes with me. A car boot is seldom air-conditioned and is vulnerable in traffic and to theft. Just my approach. I know others who think differently.
Hello stump4545,
If you replace "M9" w/ "relatively fragile precisely calibrated instrument" you can probably answer this & a number of other possible questions relating to it yourself.
Best Regards,
Michael
People, by nature, consistently "push the envelope". Not always in the most optimal direction. That's why sometimes it is good to ask a friend.
On a hot summer day, the inside of the trunk could be a bit toasty. I don't know if it would affect your equipment.
Heat can do serious damage to lenses - I saw the results of baked lenses rather frequently when working at a retail camera store. Heat is no friend to camera bodies, either.
I'd rather be safe than sorry. If its too hot for a person to sit comfortably in a car with the windows up, I won't leave my camera kit in the car. The trunk gets just as hot as the interior of the car so the trunk is a no-go too.
Just use common sense? It may be a plan.
In winter keep it in the boot while travelling so it is near outside temperature all the time (and won't steam up), in summer keep it in the car but not right underneath the air con vent.
Steve
Short answer, NO, but if you can afford a couple of M9's (use your back-up body while the cooked on is being serviced), you probably won't mind. Of course, it can always get stolen. A Leica is part of your anatomy--don't leave it behind.
This is where I store some spare equipment. It a '99 Taurus wagon "basement", realy the third row of seats which face toward the back. The section folds flat to create a lockable compartment that can be further obscured with the cargo net. It stays cool, and the car has a full-ton chassis (also used for their top SUV), but with a cushy ride. (The right compartment is just a small stash plus the emergency gas pump restart.
Bad idea,vibration, heat, theft. etc.
Color of the car makes a big difference. White reflects heat best. Black makes an oven.
I have a black and a white car and the difference is shocking.
Heat cooks grease and oils and they vaporize and settle in the wrong places.
You can dampen vibration by putting the kit on a pillow.
Keep in mind things fall off car seats.
If the advice isn't in the manual, you can probably sue Leica. <- Joke ;)
Or you can just use common sense.
If you don't want to put the camera down in the car, presumably you need to take a companion to cuddle it for you while you drive.
