One third issue
matts
I have an M9 with the latest 1.716 firmware and I'm finding that in my first few dozen shots (this camera is second hand), I've noticed that I too have gotten the bottom/top 1/3 issue:
Pretty much identical to: Significant M9 Problem. - Photo.net Leica and Rangefinders Forum
I also got a couple unreadable files. Not 0mb but just listed as problematic by Camera RAW.
I've been using a brand new Transcend Class 10 32 GB card, but I just ordered two Sandisk Ultras at 16gb in case.
Is the issue still caused by chimping when the card is writing?
Ideas?
x
Well, you will have to provide some more information rather than point to a rather nastily trolled thread on Pnet (thanks for reminding me why I never go there...:roll eyes:) to get a sensible answer.
Post a problem image. Does it show up on the camera LCD? Did you try another SD card?Did you shoot DNG, JPG or both? Does it show up on both files? etc..
I always use an external reader.
On the camera, I remember seeing one problem image which was maybe 1/5 band of correct image and the rest below was just colourful noise. I don't recall noticing that many issues on camera.
I will definitely thoroughly format my card again, though I have read that this issue may occur when one plays through while the camera is writing from the buffer.
Other things to note: I shoot uncompressed RAW and try not to use continuous (though I select it accidentally from time to time nor do I bracket.
Thanks! Precisely my issue, except this is with firmware 1.716 and there seems to be little posted on issues after that November update.
Has there ever been a solution or do you just have to hope it doesn't happen on a critical image? Are there at least precautions one needs to take?
I also was using Lightroom 4, so it isn't a CaptureOne issue.
Thanks
I have an M9 with the latest 1.716 firmware ...
What firmware version do you have? ;)
I've been using a brand new Transcend Class 10 32 GB card, but I just ordered two Sandisk Ultras at 16 GB in case.
I would try a different card, and I would stay away from SanDisk cards, particularly from the Ultra which is known to cause problems frequently. Try Pretec or Panasonic.
Thanks
Mailing the files to Solms and waiting two month I got this answer:
"Dear Mr. Thomsen,
Thanks for your mail.
The newest firmware is available. Please have a look to our homepage "downloads".
Thanks.
Leica Camera AG - Downloads
Kind regards
Customer Service"
As I have not experienced the problem since changing firmware I thought the problem was gone. But now I don't know. It will probably show up again when you are shooting the picture of a your lifetime :eek:
