diopter question
ramosa
My eye check today indicates my right eye is at -1.0 diopters. I know M8s are (without diopter correction) set at -.5. Thus, I need to purchase a -.5 diopter correction lens, right? (Thus, -.5 + -.5 = -1.0 ...)
Thanks for any help/confirmation.
If you don't want to check the strength using your optician's try-out lenses, at least walk into a chemist and use the 5 euro spectacles from his throw-away glasses stand.
Or use the proper tool ;)
Your reading strength is an incorrect value; the viewfinder elements are at a virtual distance of 2 m. So you correction should be at two meters and your accomodation should be able to take care of the virtual distance of your subject. If your eye's accomodation cannot handle that the 2m value should have precedence.
Here in the UK you don't seem able to buy -ve dioptre glasses over the counter.
in some posts online, some folks are saying my explained approach makes sense, but that they'd actually recommend getting a -1.0 diopter and find that it works better. any experience with these things?
Yes, this would be the way to go. Provided your eyes still have some focussing accommodation (which tends to evaporate at around age 50) you will be fine.
Quick test: with a prescription of -1.0 you can probably read screen text at about a meter. Do that, and then hold your hand 20cm from your eyes (a hand span away). Can you focus on your hand? If so, -1.5 overall diopter adjustment will work. Your eyes will cope.
Enjoy. :)
