Transparent changing bag for M9?
atournas
OK, I did my best, but some dust bits apparently got onto the sensor when I changed lenses on the M9. So, I wonder, would it be useful if there was a transparent changing bag, dust-tight instead of light-tight, for cleanly changing lenses? In theory, a conventional changing bag would do as well, but only after some practice and it might work as a "hit or miss" accessory.
Paul
Don't worry about, clean the sensor when the dust is obvious. Dust is inevitable with a camera that has removable lenses, the trick is to learn to cope with it.
Even if you used a bag, how would you ensure that the bag itself was dust free?
Hi Paul,
is this something that your looking for.??
Just Ltd - CameraBivvy Pop-up tent..
Koh Global, LLC. Bag System
koh hepa also does dust air purifiers to clean the bags whilst changing lenses,
i apologise now to the mods if i'm not allowed to post links here,still new to this forum stuff.
Simon
Guest WPalank
Dust or oil just happens. There is always the chance that it is some sort of lubricant (oil based that you are seeing). A lot of people (and I believe Leica) dismiss the idea of there being anything internally that could be oil based. Although I have seen it but not the source.
I always diagnose the spot first. I use surgical loops with fiber optic light and even sometimes a surgical operating microscope (I guess you can use the high magnification device that one of the vendors sells). Then I reflect light in from the side. If oil, in my experience, it reflects a rainbow color much like the sheen you get on roadways after a rainy day.
Finally I use a wet cleaning product based on what I find. Much like cleaning clothes with specific detergents (or solvents) selected on what sort of substance I am trying to get out of the clothes.
open the bag to put camera in,and dust goes in also. It is in the air and on the camera already.
The best things you can do
Change lenses with your back to the wind
Keep the camera lensless as short a time as possible
Keep rear caps on lens and keep the cap inside dust free
Keep camera mount down,drop off old lens, have the new already oriented and blown off with your rocket blower, put it up to the camera
Blow out the inside after every outing to get anything that may have found its way inside. This is a precaution to remove dust before it migrates to inside the shutter/ sensor.
I have cameras for years that have had no dust incursion. Just use some caution.
Every few years I clean the sensors as a matter of principle.
When I change a lens whether indoors or out, I have the lens I am going to put on ready and take other off and there is so little time uncovered I rarely get dust inside. It is a two handed thing, I take the lens off the camera with one hand by pushing in the button and rotating with one motion. Just take a little practice.
Wouldn't you rather just clean the sensor every now and again and just get on with your photography in the meantime? It is easy to clean your sensor, you are meant to clean your sensor, and you are meant to change lenses as often as you want to.:)
Steve
Thanks, Simon, for the link to the Pop-up tent. It probably makes sense in certain conditions. I photograph often in the extremely dusty environments, such as agriculture (hay), or shipbuilding (sawdust), where above recommendations do not apply.
But I laughed loudly at "camera not included" in the Pop-up tent ad.
Did I ever mention I can't stop washing my hands?
Do you know if the little light in my fridge goes off when I close the door? I open the door to find out and it's on but I don't know if it was off until I opened the door ...
Pete.
Pete.
Pete, you've got several cameras with timer releases. You can find out if the lights go out shortly after shutting the door. The D2 also has an electrical release which I'm sure you can operate from outside the fridge.
Hence, you can make sure that the lights burn at most when there's no camera in the fridge.
Pete.
You had to mention that? I thought I'd gotten over that one... sleepless nights ahead of me now. Which reminds me of a joke:
Did you hear about the dyslexic, agnostic, insomniac? Lies awake at night wondering if there really is a Dog.
Pete, you've got several cameras with timer releases. You can find out if the lights go out shortly after shutting the door. ...
I have 21, 28, 35, 50, and 90 mm lenses. Which lens should I use for this, Philipp?
Pete.
Pete.
In order to do this properly, I feel one should use a mint instance of the WATE. Otherwise, do avoid lenses which tend to do cushions; for this application, barrels are to be preferred. OTOH, given the pigmy fridges people tend to install, this could be a very fine case for the Tele-Elmar on the Visoflex III, preferable with the Bellows II. For the white balance to work properly, set the camera to manual. Make sure to adjust it with the fridge wide open and the kitchen in complete darkness or mixed lightning might result which can be frightfully difficult to handle in PP. On the other hand, the temperatures to be expected within the fridge might reduce any thermal noise issues to some extent. Unless you have a fridge you can walk into, no neck strap seems to be called for.
