Leica lens profiles for Lightroom
rramesh
I have seen some forum members like sokolovs publish lens profiles for Leica lens.
Since Leica ships Lightroom for all M customers as part of purchase, shouldn't they publish appropriate lens profiles. Coded lens may have this corrected but what about non-coded lens?
After all manufacturers like Zeiss have a complete library of lens profiles for all their M mount lens.
  • 2 weeks later...
That's because Leica lenses don't need correcting ;)
I wondered this my self especially since Lightrrom is bundled with the cameras....it's strange.
On a number of wideangles distortion certainly needs correction.
Take a look in LR4 where you will now find at least 20 Leica M len profiles included (additional to the S lens profiles).
I have never seen any need for them myself. I would speculate that these were generated by Leica Camera themselves and provided to Adobe.
Lens corrections are part of the Develop Module. You can choose whether to enable the standard ones for the detected lenses or custom ones or make manual corrections or correct chromatic aberrations
In terms of ultra wide angle lens distortion at the edges, does the M9 correct for that in camera (for the 18mm Super Elmar causing my daughter's body to be stretched wider for example on film) or will it be more corrected in LR4 when the specific lens corrections are applied in the develop module.
Even the near perfect Summilux 50/1.4 ASPH is corrected by LightRoom 4: the tiny amount of pincushion distortion is corrected as well as the nearly invisible chromatic aberration. The reduction of purple fringing is a bonus that can be switched on in the manual part of the lens correction module.
There are 21 Leica M lens profiles included. You can also define your own profile.
There is also a 2012 Process added, which produces a slightly darker image than the 2010 process I used in LightRoom 3.
