The hotshoe on my X1 is so tight that I practically have to force the Leica finder in each time I want to mount it. Taking it out from the hotshoe is another hassle. It is impossible to mount any of the flashgun that I have to the hotshoe. Does anybody else have the same problem? Any suggestion how I can 'loosen' it a bit? Thanks.
Strange, I had this same problem whe I tried the finder out on my X1. I had to use so much force to attach it that I was really concerned I might break the shoe off. Similarly, excessive force was needed to remove it - in fact in finally came off with such force that it shot a couple of feet across the sofa (landed safely with no damage).
I am sure it must loosen up a little with use but it needs to remain tight after attaching it many times, as there is no locking mechanism to secure it in the shoe. In the short time I tried it out, I felt my copy was too tight and was relieved to return it for credit (for reasons other than the tighness).
Sorry to hear the problem. I can see how it is damn awkward for the flashgun.
If any use as an very alternative suggestion, I now keep the VF mounted all the time, have sold my SF 24D flash because I found the results from the Metz 28 CS 2 slave flash even better. Since Leica Flashguns seem to go for good money, I was able to Swap them around and fund the Metz out of double the amount of money it cost, that I realised for the 24D.
May I suggest to you people to carefully apply a fine nail-file to the appropriate surfaces (not bottom) of the viewfinder mount? You probably have one in the house if you or at least your mate grooms her nails.
I too found it tight but prefer it that way. In the end I rubbed a pencil on the edges to give some graphite "lubricant".
Powdered graphite is the very worst thing to ever apply to any part of your Leica. If finds it's near-nanosize particles into everything. It's a BAD THING!
Loading...
    No registered users viewing this page.
  • Similar Content
    • By Julius Yls
      Sharing my short article shooting Paris with classic Leica X1: https://www.juliuspictures.com/blog/2020/11/13/exploring-paris-with-leica-x1
      I found this little old camera is amazing. I hope you all enjoy it.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    • Guest
      By Guest
      Hallo zusammen,
      da ich mich über meine Neuerwerbung sehr freue, muss ich dies hier kund tun. Ich habe zuletzt etliche Jahre mit einer Leica X1 fotografiert, dann bin ich vor 5 Jahren auf eine M9 umgestiegen. Damit fotografiere ich regelmäßig und es macht mir eine Menge Spaß.
      Als Erbstück von meinen Eltern (meine Mutter war Fotografin) habe ich eine Leica IIIc (Baujahr 1949) mit einem Summitar (von 1951) 5 cm, 1:2, die sich - damit Objektiv - in einem sehr schönen und voll funktionsfähigen Zustand befindet. Damit habe ich in den letzten Wochen 2 Filme belichtet, um zu sehen, ob ich überhaupt noch analog und jede Automatik fotografieren kann. Es hat funktioniert.
      Da die Schraubleica nicht wirklich einfach in der Handhabung ist (Sucherfenster und Entfernungsmesser separat) habe ich über die Anschaffung einer M3 oder M2 nachgedacht.
      Für die M3 spricht, dass Sie über einen besonders großen Fenster verfügt.
      Für die M2 sprach ihr Aussehen (sehr schlicht - sehr schön) und die Tatsache, dass man mit ihr problemlos ein 35 mm Objektiv nutzen kann.
      Nun ist es eine M3 - Kauf per Ebay (trotz grundsätzlicher Bedenken) geworden und ich kann meine Leica-Optiken (meistgenutzt: 50 mm) für den Oldtimer nutzen.
      Ich bin gespannt darauf, sie in der Hand zu halten und den ersten Film zurück zu erhalten.
      Beste Grüße
      Dieter M.
    • By hanskb
      Der einsame Mundharmonikaspieler in der Corona-leeren Einkaufsstrasse
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!Leica X1
    • By Knives52
      I picked up a Leica SF24D flash recently to use with my M6TTL. I was thinking about testing it with my Canon EOS R dslr and using its screen to get familiar with the flash without wasting film (I don’t mind if it will only work using Manual mode on the flash).
      I think I remember hearing years ago something about TTL flashes not pairing well with some newer “more-electronic” cameras’ hot shoes and possibly frying the camera’s electronics — though my memory’s extremely foggy on that.
      Does anyone have any experience using the SF24D on a dslr of any make/model and/or on any digital Leica body?
      Would covering the flash’s 3 “TTL connector pins” on its hot shoe with electrical tape (while leaving the main center pin uncovered) be necessary or safer?
      Apologies in advance if this is a dumb question.
    • By robert blu
      Leica x1 : still works
