Filter for Elmar 5cm f3.5?
I mostly use a yellow filter for my b&w films and now that I have acquired an Elmarit 5cm f3.5 (1951), I am looking to see what filter to use. Leica Wiki etc tell me that filters are A36 (clamp-on?) and I have read that most people use a SNHCO adaptor so that a standard E39 filter can be used. Am I on the right track and if so, how difficult is it to acquire a SNHCO?
Keith,
Walz made 22mm(?) diameter filters which screw into the black ring around the front lens element. They occasionally come up on that online auction site and I managed to acquire a set of 5 marked "Walz for Elmar" in a clear plastic storage case and fine leather cover quite cheaply a few months ago.
My set has light green, red, orange blue, and yellow filters.
The filters allow you to adjust the Elmar's aperture without having to remove the filter.
Pete.
Peter,
Thanks for the info. The thread on my 1951 Elmar (Ser No. 904xxx) looks to be circa 19mm (i.e tiny). I find it somewhat difficult to visualise a filter that would not interfere with the aperture adjuster, especially if an adaptor is used!?
Keith,
My filter thread is the same - I only roughly measured the outer diameter of the filter. As you can see from the photo below, the aperture tab (not visible) can still be adjusted with a fingernail as before.
Pete.
Keith, be aware that the adapter you quoted in your original post is indeed the SOOGZ - 13154 : to mount std. E39 filters on lenses that accept the old A36 filters (Elmar and others); of course, with filter mounted no operation on f stops ring... :o
This is my one :
And quickly found one for sale on e....y : LEICA S00GZ 13154 a36 to e39 39mm FILTER ADAPTER ELMAR **BEAUTIFUL** | eBay
Another possibility: the graduated yellowfilter FIRAD:
There's another SOOGZ here, and slightly cheaper (no association with vendor):
Leica Leitz SOOGZ Adapter Filter E39 an Objektiv A36 Filteradapter E 39 an A36 | eBay
I bought one recently to fit a lens similar to the old Elmar 90/4, but paid a little more than this one here. If I didn't need to use the IR cut filters, I wouldn't have bothered with the SOOGZ and just used the A36 clip on filters.
The "original"
...and 'the original' looks to be just what I need (i.e. a yellow filter that screws directly into the circa 19mm thread). What is the code name and/or part number of this item? Or is it a Walz item as mentioned in post #2?
I note that JC's filter has a black rim whereas mine and the other Walz's I've seen are silver chrome. It may be Leitz original that I've never seen before.
Pete.
It can be a FICAT :) Luigi non ridere, esiste.
Edited by jc_braconi
Thanks! FICAT is listed in the Leica WiKi as:-
FICAT No. 1 light yellow filter; screw-on type F
Whereas I would prefer a medium yellow and the corresponding item is listed as:
FICOM No. 2 medium yellow filter; screw-on type F
So, if 'Type F' refers to a (circa) 19mm thread, then a FICOM is what I shall try to find!
But there again, a search just now on Google for FICOM turned up 'The 1931 Leitz Camera Catalogue' which shows I could really need either a FIRMY (No. 2 yellow) or as an alternative the FIRHE (No. 1 yellow). Decisions, decisions...
Many thanks for all of the inputs. :)
Edited by Keith (M)
added Google search info.
Loading...
