M9 and iCloud as a transfer medium
chap
If images - RAW or JPEG - are downloaded to an iPad and then transferred via iCloud to a home computer, are the images of the same size? Does iCloud compress files? Yes, I know there are hundreds of better ways of doing this, but my question is specific to how iCloud would handle M9 images. Thanks.
iCloud is limited to 5Gb which is ok for transfers but a bit niggardly as an off-site storage solution.
It should mirror onto all your devices exactly what was filed onto any device.... so Raw +/- JPG stored on an iPad from an SD card should appear exactly the same on all devices.
You will need a fast internet connection or it will drive you mad.... and if using mobile devices if could cost you a packet as the data volumes with M9 Raw files will escalate rapidly.
Sounds like a great idea ....particularly if abroad .... but you may come back to a horrendous mobile bill....
I tried several times to use the iDisk feature with MobileMe (iCloud's predecessor) for what you're proposing and the experience was painfully slow in the West. In China I found it impossible, as the upload and download speeds were much worse (going through the Great Firewall). In the end I resorted to multiple backup drives as being a much faster and more reliable solution.
The 5GB limit is for the FREE version, you can buy larger capacities if you need/want.
I've tried using my iPad for temporary storage but gave up as the DNGs never seemed to render properly, so now prefer to use my MacBook Air, which is roughly the same size and has a far larger capacity.
There's no need to be like that about it.
30 days of photos taken with iPhones and iPads are saved. As far as I can see, there's no way to upload other image files for storage there.
From what I have heard, iCloud is being developed and other services are due to be added.
This is how I use it when I travel:
I shoot DNG+JPEG basic.
I transfer the DNGs and JPEG to the iPad from the SD cards.
I look at the JPEG files on the iPad, which look reasonably well.
I then tell the iPad to back up to the iCloud (I have a 25gb storage account), over a WIFI network it is slow but reasonable.
Once I get back home, I copy the DNG files to my computer for editing and on to glory, I delete the JPEGs as I have no use for them beyond browsing them on the iPad.
I then tell the iPad to back up to the iCloud to delete the remote back up files... and Bob's your uncle as my friend loves to say (very cryptically I might add).
Ymmv.
I could not get RAW images to display on my iPad, but JPEGs work fine.
Ymmv.
Did you ever try to view DNG files on your iPad? Mine only says RAW (I believe), and I cannot get a thumbnail to build.
DNG (RAW) files will open on the iPad using the built in Jpeg that is only good for the small M9 screen, so it is a very very mediocre image...The only way to see the image at a reasonable quality is to shoot at DNG+JPEG basic with the M9.
