albertknappmd Posted February 15, 2007 Share #1 Posted February 15, 2007 Advertisement (gone after registration) How do you get the little colored icons to migrate into the message area? I can only get them up to the title area? What is the secret !!!!!! Link to post Share on other sites More sharing options...
farnz Posted February 15, 2007 Share #2 Posted February 15, 2007 Albert, You need to use the Enhanced Interface Editor. Select "Edit Options" from the "Quick Links" link on the bar above, go to the "Miscellaneous Options" panel at the bottom of the page and select "Enhanced Interface - Full WYSIWYG editing" from the "Message Editor Interface" drop down menu. Next time you use the editor there will be a selection of 'emoticons' on the right hand side of your editing panel. HTH, Pete. Link to post Share on other sites More sharing options...
carstenw Posted February 15, 2007 Share #3 Posted February 15, 2007 You can also just type old-style smilies, like : ) and ; ) and so on. You need to find the codes for all of them though. Note that I needed to leave a space between the : and ) to make them show up as characters rather than smilies. You shouldn't do that. Link to post Share on other sites More sharing options...
albertknappmd Posted February 15, 2007 Author Share #4 Posted February 15, 2007 Thank you, Albert:D Link to post Share on other sites More sharing options...
truando Posted February 15, 2007 Share #5 Posted February 15, 2007 Thank you, Albert:D that was cute! Link to post Share on other sites More sharing options...
