AWB problem
kepstein
WB & a lot of IR contamination from the lighting.
You will find that the WB becomes MUCH more consistent when using the IR filters, however it still does need improvement in firmware.
Basically for color you really need to use the IR filter for most lighting.
Best,
Ray
I presume you are using the Lightroom beta, as am I. This version sometimes does this. Try developing that shot in C1LE, which came with the camera. It does much better. The final release of Lightroom is meant to be much improved.
Yes, those pictures are imported into Lightroom, but when I import the Raw file into C1, it looks the same before processing.
