mjh Posted February 10, 2007 Share #41 Â Posted February 10, 2007 Advertisement (gone after registration) My source tells me that FW 1.10 will not address the IR issue This should be common knowledge by know. Â nor Leica intends ever to fix it. For now the IR cut filter seems to be the only way Indeed, IR cut filters ARE the fix suggested by Leica. Firmware version 1.10 is necessary for automatically eliminating the red vignetting (aka cyan corners) issue with IR cut filters and some wide-angle lenses. Â unless the problem specific profile is used to correct the color shifting. You can fix the shifting from black to magenta using colour profiles, but not IR-induced colour shifts in general. An IR cut filter is the only universally applicable fix available. Link to post Share on other sites More sharing options...
sean_reid Posted February 10, 2007 Share #42 Â Posted February 10, 2007 My source tells me that FW 1.10 will not address the IR issue nor Leica intends ever to fix it. For now the IR cut filter seems to be the only way unless the problem specific profile is used to correct the color shifting. Can anyone verify this? Â Hiro, Â The IR sensitivity isn't something that a firmware change can fix. What 1.10 will do is to compensate for the cyan drift when 35 mm and wider coded lenses are used with 486 filters. Â Cheers, Â Sean Link to post Share on other sites More sharing options...
sean_reid Posted February 10, 2007 Share #43  Posted February 10, 2007 @ Sean--happy upcoming birthday, if I forget to wish it to you on the day! Many happy returns!! @ Blasko and others: Leica *did* deliver a firmware upgrade already! Remember 1.09? That's not what my M8 came with!  Thanks Jamie.  Cheers,  Sean Link to post Share on other sites More sharing options...
hiro Posted February 11, 2007 Share #44  Posted February 11, 2007 Hiro, The IR sensitivity isn't something that a firmware change can fix. What 1.10 will do is to compensate for the cyan drift when 35 mm and wider coded lenses are used with 486 filters.  Cheers,  Sean   Sean,  Many things have been said under different topics but now I understood. Thank you for clarifying all this.  Cheers, hiro Link to post Share on other sites More sharing options...
sean_reid Posted February 11, 2007 Share #45  Posted February 11, 2007 Sean, Many things have been said under different topics but now I understood. Thank you for clarifying all this.  Cheers, hiro  My pleasure Hiro, welcome to the forum.  Cheers,  Sean Link to post Share on other sites More sharing options...
eronald Posted February 11, 2007 Share #46  Posted February 11, 2007 Hiro, The IR sensitivity isn't something that a firmware change can fix. What 1.10 will do is to compensate for the cyan drift when 35 mm and wider coded lenses are used with 486 filters.  Cheers,  Sean  Sean, are you finding my profiles useful with the Leica filters ? What are the differences between my profiles and Leica's own upcoming profiles ?  Edmund Link to post Share on other sites More sharing options...
sean_reid Posted February 11, 2007 Share #47  Posted February 11, 2007 Advertisement (gone after registration) Sean, are you finding my profiles useful with the Leica filters ? What are the differences between my profiles and Leica's own upcoming profiles ? Edmund  Hi Edmund,  I haven't had a chance to download or try them yet. I will as soon as I can.  Cheers,  Sean Link to post Share on other sites More sharing options...
