Voightlander 15mm Heliar w/adaptor - Which M8 lens code?
wstotler
maybe I'm misunderstanding various comments. but I'm not convinced the frame selector lever postion, and correspondingly, the frame coding bump on the adapter, has anything to do with the exif data.
I have my 15 Heliar coded for a 21 and it shows 21 in the exif data, in each postion of the frame selector lever.
Hi John,
Some codes will only trigger recognition if the frame line selector lever is in the correct position. For example, to trigger the code for a Zeiss 21, one has to hold the frame line selector in the 28-90 position. This is because the Zeiss bayonet doesn't automatically trigger those (correct for Leica) frame lines.
I'm loving the milled adapters, thanks again.
Cheers,
Sean
