DerrickC Posted February 5, 2007 Share #1 Posted February 5, 2007 Advertisement (gone after registration) Hi, i'm new to Capture One LE and have been trying to convert some M8 raw files. When i process the files and open up the Jpegs, the image looks kinda blocky (like the image has small square bands around the whole image when viewed at 66 to 100%, as if a grid of small squares was placed over the whole image). Looks like an image that has been over sharpened but i disabled the sharpening. I tried converting the same image in Photoshop and did not have this problem but getting the white balance right using PS seems alot harder. Any ideas what i might be doing wrong. Any good workflow tutorials on C1 LE? Appreciate any help. Thanks! Derrick Link to post Share on other sites More sharing options...
carstenw Posted February 5, 2007 Share #2 Posted February 5, 2007 If the small square blocks are in a regular grid, you may have the JPG compression set too high. This is a JPG artifact. Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted February 5, 2007 Share #3 Posted February 5, 2007 Or your file size is set to low Link to post Share on other sites More sharing options...
wparsonsgisnet Posted February 5, 2007 Share #4 Posted February 5, 2007 Derrick, just for the record, you will be able to view the jpg's in C1 but you won't be able to operate on them. C1 only mani;pulates raw (or dng) images. Link to post Share on other sites More sharing options...
DerrickC Posted February 5, 2007 Author Share #5 Posted February 5, 2007 Thanks for the replies. Don't think it had anything to do with the file size or compression. I tried converting the RAW file to both jpeg-high and tiff-16. Could it just be noise? The image was shot at iso 640 and was pushed 1/2 stop. Here is a 66.7% crop of an image (effect seems to be more pronounced at this magnification on screen) Can see it on the hand:- Here is a 100% crop of a part of the image (seems quite ok):- I don't remember seeing this kind of thing on any of my RD1 files at any magnification. I must be doing something wrong. Link to post Share on other sites More sharing options...
