DL4 viewfinder on X1?
symmetron
I have both a DL4 and X1 and am shopping for a viewfinder. It would be nice if the viewfinder worked on both cameras. I understand that the DL4 viewfinder also has lines for 35mm. Is anyone using the DL4 viewfinder on the X1 and if so, how well does it work?
To be honest I tried the small EVFinders, I found them to small to actually see thro’’
So I went overboard & now use the “Big Daddy”” interchangeable between DL4 & X1..
It makes both cameras “For Me” :)
Yes indeed the DL4 finder does have lines/frame for 35mm , but the finder is not as large and bright as the X1 finder ... i have looked through both side by side and already use a DL4 finder.
Brian
I have the dl4 viewfinder and as far as I know it is optically very close if not equal to the Leica M 24mm viewfinder (which costs quite a bit more). I bought it to use it with my 24mm on the M9.
I can not see how it would not be bright enough, it is very good.
Now if the 35mm frame is too tight or not might be a different story. I dont find it a problem.
Personally I have canceled my order for the x1 viewfinder and told myself I would just use the dl4 viewfinder.
But then I use the x1 without external viewfinder all the time anyways.
I dont know if the AF-position might be indicated in the x1 viewfinder??
So I bought the 36mm X1 finder. I've pretty much gotten into using it all the time with the LCD as a a backup. So now it's like the X1 has a built in viewfinder. Somewhat of a surprise as I expected to use it only outside when the LCD was not useable. :cool:
Don't you use the histogram?? Or do you put it on auto shutter and aperture?
A wise decision as it is better than the DL4 one ... i use finder and screen ... infact i "chimp" (i believe this is the term) a lot and have 2 batteries.
Brian
