Englander Posted February 1, 2007 Share #1 Posted February 1, 2007 Advertisement (gone after registration) I do not know how much disassembly takes places when lenses are coded. Looks like the mounting ring is replaced but whether lens units are removed from mounts before ring is removed, I don't know. What I do know is that my 35/1.4 ASPH has a new mount ring and no longer focuses properly. It does not coincidence at infinity with any of my Ms and is off by 100 mm at 2 meters; i.e. focuses 100mm past the subject at 2 meters. A change in thickness of mounting ring, or a shim that wasn't replaced on reassembly would be enough to cause this. I have sent a note to Leica Service. No reply yet, of course. These days you need to double check everything. Be careful out there.... Joe Link to post Share on other sites More sharing options...
Advertisement Posted February 1, 2007 Posted February 1, 2007 Hi Englander, Take a look here Double Check your lenses after coding. I'm sure you'll find what you were looking for!
