M8 horizontal leveling
anfrve
Hi everyone,
As not yet an M8 ( i hope sooner as possible) owner i would like to kown if anyone has experienced or find problem to leveling horizontally (due the shorter baseline of the sensor)
the camera.
This happens oftenly, with my canon s 70 poket size camera, but also experienced with some reflex with aps size sensors cameras.
bye Andrea
Hi everyone,
the camera.
bye Andrea
I suppose you meaan keeping the horizon straight :) You'll find the viewfinder is so different from a DSLR that it is a completly different experience in use.
you're right jaapv :D
i'm experienced with the viwfinder, (i own an M6) i mean how difficult is to mantain it straight, due his shorter baseline
Andrea
i find it easier to just print them crooked and adjust peoples head when they look at my pictures :D
Seriously, i'm having a major readjustment to RF even though i started there and horizontal leveling tops the list.
surprisingly i can't hold it very steady or i jerk when i fire? may try one of those soft shutter releases.
bill
Bill,
Try using the 2sec self timer while shooting something that isn't timing dependant. This was you don't have to press the sutter to take a shot. It should help you determine if it is your pressing doen or just that you aren't holding it level.
- Carl
After reading your post I did some tests because I to am seeing tilted image more with the M8 then I did with a Nikon D200 or any of my M3's and the R4s when I'm hand holding.
I originally chalk it up to either the sensor is misaligned or the frame lines are off from the sensor. I mounted the camera on a tripod that has a level built into the QR and then placed a level on top of the camera. Both read good. I then placed something infront of the camera that had lines on it, focused and snapped. The picture was right on or nearly right on. So I gues it's me holding the camera at a angle.
I now make sure the frame line are lined up with what I want to be level or plumb.
I had terrible trouble with tilted horizons using an RD-1 a couple of years ago. I eventually got tired of realigning the images in Photoshop (and losing the best part of 10% of the image area) and went back to my trusty M7 bodies. I've had no such problems with the M8 - the finder is up to the usual M standard.
I carry a small inexpensive 'shoe mount' spirit level in my pocket at all times. When tripod shooting the spirit level always goes on the camera, and when I'm not it stays in my pocket and ensures that I have gorgeously straight trousers.
I wonder if this helps...............Chris
So when your trousers are gorgeously straight, we are to assume it is the level in your pocket and you're not just happy to see us?
Danni
My theory on it is that in the 'classic holding pattern' the left hand is underneath the camera "pushing up" whilst the right hand is on top "pushing down". This is a natural set-up for rotation that occurs. From time to time I fight it consciously, but often give into "Carsten's theory". ie it's a creative element.;)
Cheers,
Erl
