lburn Posted April 12, 2011 Share #1 Posted April 12, 2011 Advertisement (gone after registration) I want to use a polarisor filter on the Tri Elmar and have the 67mm filter adapter. I have just bought a Kenko 67mm polarisor circular filter which is sold as designed for rangefinder cameras because it has a rotating calibrated rim which can be matched to a hot shoe (or hand held) polariser with a matching rotating rim. That allows you to see the polarising effect you are getting and then match it on the camera. The problem is that, because of the thin rim, the filter will not fit far enough back into the filter holder to engage with the 67mm threads. I wondered if anyone has had this problem and knows of a solution? Lburn Quote Link to post Share on other sites More sharing options...
Advertisement Posted April 12, 2011 Posted April 12, 2011 Hi lburn, Take a look here Tri Elmar 16-18-21 filter use. I'm sure you'll find what you were looking for!
AlanJW Posted April 12, 2011 Share #2 Posted April 12, 2011 I don't use the Kenko but I do use a B+W 67mm without a problem. The cutout in the filter adapter allows me to rotate the polarizer until it is darkest. Works reasonably well for me. No issues at all with the threads. Quote Link to post Share on other sites More sharing options...
tdtaylor Posted April 12, 2011 Share #3 Posted April 12, 2011 I have the Nikon Slim Polarizer, and have had no problems- use it the same way as WeinschelA, although only at 21mm. When I am using both my Nikon and Leica equipment, I use a 67-77 step up, and just use 77mm filters that match the Nikons- just have to deal with the finder blockage. Quote Link to post Share on other sites More sharing options...
lburn Posted April 14, 2011 Author Share #4 Posted April 14, 2011 Thank you both for that advice, its very helpful lburn Quote Link to post Share on other sites More sharing options...
vanhulsenbeek Posted April 14, 2011 Share #5 Posted April 14, 2011 Do watch out for unwanted refections; I had to black out the white lettering on the front of the WATE (with schoolboard paint), before I could use filters of that size in a filter holder. Quote Link to post Share on other sites More sharing options...
