M8 Lens detection, EXIF and 6-bit encoding
sparkie
No the actual f/stop is not recorded, only the maximum(fastest) aperture of the lens is recorded in EXIF. This is the limit as there is no communication of the aperture used during exposure from lens to camera(manual lenses).
Actually the f-stop used is deduced by the camera from the "blue spot"sensor, and used for vignetting correction on coded lenses, but as it is not completely accurate it is not recorded in Exif.
There is, however, apparently an estimate of the aperture that is used for vignetting and related corrections. This is not recorded in the EXIF data, but I imagine it could be, and believe it could be useful if it was. This estimate is apparently derived via the "blue dot" sensor that measures overall subject brightness. Presumably the firmware considers ISO setting, shutter speed and exposure compensation in determining the approximate aperture.
Jaap beat me to it!
You guy's are really trying to give me an alzheimer panic attack :D
If your lens is properly coded the information relating to maximum aperture is recorded in the Exif info. I began to doubt my self and checked the Exif info on some leica coded lens shots, a 75 Summicron and 21 Elmarit. I checked in C1 Pro, CS2 and Aperture. All correctly report the maximum aperture as f/2 for the Summicron and f/2.8 for the Elmarit. I've just done this now so I'm not imagining that it's there.
The only time I have seen the f/1.0 is when the lens detection is switched off or the lens is not properly "locked" into place giving a the default f/1.0. Or if the lens is not coded at all.
If you have any home coded lenses you should be able to test the accuracy of your marks by reviewing the image on the camera screen and pressing info. You should then see the lens focal length and the maximum aperture displayed, if the max aperture is not displayed the camera did not pick up the code correctly or the code is out of alignment. Therefor this may be the reason your C1 Pro or CS2 is showing f/1.0.
Have a look again,
I checked and opened some more files shot the other day. And I looked again at the bottom of my 28/2.8ASPH and it definitely has the 6-bit coded dudad. and I distinctly remember turning ON lens detection in the menu. The weird this is that CS2 is showing that it is a focal lenght of 28.0 mm so in some way the lens detection is working, but no max f-stop acknowledgement. contrast this to a 35/1.4 uncoded lens which shows nothing but shutter speed and ISO speed ratings with a max aperture value of f1.0.
And YES, I remembered to take my pills this morning. So I'M not imagining this either! maybe something is wrong with my came (apart from the stuck VF framelines) *sigh* :cool::p
I think the info for the lens focal length is a combination of the 6bit and the frame lines, for example before I coded my 35'lux it showed up as 35mm with max aperture of f/1.0. I have noticed something funny with this lens after coding the max aperture would show in the exif data as f/2.0 within Aperture but show f/1.4 on the camera. I'll have to check this one again and see what it's showing now (the old memory is in serious doubt today). I know for sure the 50 Summicron is not coded but it shows up as 50 f/1.0.
Do you have any pills to spare? !!
It is clearly a 1.09 firmware bug. My first gen camera did it correctly on 1.06, and has reverted to recognizing only the focal length on its conversion to 1.09. There seems to be no difference whatever in the practical result on the file however. I suppose it will be fixed in 1.10.
thanks for the clarification guys
Eoin, I have plenty of pills. what colour would you like !? :D
"You take the red pill and you stay in Wonderland and I show you how deep the rabbit-hole goes. (Long pause; Neo begins to reach for the red pill) Remember -- all I am offering is the truth, nothing more."
I saw what happened to him :eek: , I'll take the blue one, thanks. But not a diamond shaped one. :cool:
