I want to consider the implications to removing the AA filter on 4/3 camera
accepting there would be moire on occasion, and other colour aberrations in pursuit of more sharpness
I can think of 3 conditions:
  • 1. replacing the AA with a thinner weaker version, 'if' you could find out what that was
  • 2. Just replacing the IR filter without the AA in place
  • 3. Leaving both the AA and the IR off and using an IR cut on the lens as per M8
Remember that when you remove a layer of glass between the ccd and the lens, you are shortening the optical path, which means that the infinity setting of the lens will change to some finite distance. It's worse the other way. Add glass, and the lens will no longer focus at infinity, just as if you moved the lens mount out a bit.
scott
yes i understand all that
but since it has no manual focus, just manual focus adjustment (fly-by-wire)
and the AF would work as per normal, if infinity can still be found it should work OK
the sensor cleaning would be a big issue to overcome
it would probably be disabled as a result
i did find this
n the Olympus E 4/3rds models, the AA
filter is fixed to the sensor and a thin plastic membrane just in front
of the AA filter is vibrated to remove dust.
the AA filter is separated from the sensor by a vacuum or air space, and glued
round its edges only.
